Question about Silver King Force and Suction Pump SKFSP
My silver king force pump will not pump against 80 psi does it need to be rebuilt and is there a kit
Fuel pump pressure on 1969 small block camaro
6-8 psi, usually will give 60-80 gph (gallons per hour)
Feb 03, 2015 | 1969 Chevrolet Camaro
2008 road king fuel injection just stopped runnig on freeway doing about 80 mph.checked code P1353 and p1356 which I think is combustion. Changed plugs also checked it is getting spark. Anyone have any...
If you have a fuel tuner, bypass it to see if the issue resolves. If so, download a fresh map and try it again. If the problem returns call tech support for your fuel tuner manufacturer, it likely needs to be replaced.
Oct 31, 2013 | Harley Davidson Motorcycles
How much pis in front forks hd flhr road king
15 psi is the Factory recommended pressure.
Try it. If it feels too spongy pump it up to 18-20. If you need more give it a bit more but never go over 25 psi!
If it feels to harsh drop the pressure to about 10 psi.
Worth checking your fork oil too. You really need clean new oil every 10,000 kilometres (6,000 miles).
Feb 27, 2013 | 2000 Harley Davidson FLHR-FLHRI Road king
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
Grey solutions seep out
Usually indicates that water is leaking past piston seals into oil of crankcase.
Remove oil plug and check for gray foamy oil in crankcase. If oil looks normal (compare to motor oil) oil may be entering pump chamber (not very likely due to high pressure, generally water will be forced into crankcase). If foamy oil is found, time for reseal kit or replace complete pump.
Dec 18, 2011 | Karcher 2500 PSI Pressure Washer
Two things, first what are the tyre pressures for a 2001 Road King FLHRC and The fuel pump is whistling, high pitched, can an additive to the petrol fix this.
Ok, for "one-up riding", tire pressure is 30 psi in both tires. For "two-up riding", increase the rear pressure to 36 psi.
If the fuel pump is whistling, I doubt seriously if any gasoline additive is going to help but I don't guess it would hurt to try it.
Good Luck!
Dec 31, 2009 | 2001 Harley Davidson FLHR - FLHRCI Road...
Triumph Bonneville T120 oil pressure issue
The oil pressure on a new engine is:
Idle is:  20 - 25 psi
Full pressure is 68 - 80 psi.
Pressure switch operates at 7-11 psi.
The pressure switch could be faulty.
Pressure when hot may be very low
and  if it is returning oil to the tank
that is a good sign it is still pumping.
Aug 19, 2009 | 2004 Yamaha V Star Classic
Will not work at all.
I was trying to use the gun in the wrong sequence. First you push the contact safty mechanism against the work and pull the trigger. When it's done the other way, it will not operate.
Apr 05, 2009 | Tools & Hardware - Others
Oil pressure gauge reads 80 psi with engine off and pegs running
That is probably a defective oil pressure gauge or a broken oil pressure sender, it reads 80 psi just because that is the maximum value allowed.
Pressure can be verified by reading it with a gauge tool.
If you really have pressure over 70 psi when engine is running then start replacing the oil filter, and check that the oil lines from pump are not obstructed, if there is nothing in there then replace oil pump.
If instead the gauge reads 80 with engine off, that is a defective pressure gauge.
Feb 25, 2009 | 2003 GMC Sierra 1500
Silver King Force and Suction Pump SKFSP Logo
48 people viewed this question
Top Silver King Plumbing Experts
Donni Steen
Tom Chichester
Are you a Silver King Plumbing Expert? Answer questions, earn points and help others
