Question about Power Patrol Battery 12v 7ah Rechargeable Sla Sec1075 Power Patrol
Battery date codes - Power Patrol Battery 12v 7ah Rechargeable Sla Sec1075 Power Patrol
I have a iBM t40 2373 Thinkpad when i turn it on i get 2 codes one is 0176 and the other is 0271
The first code is a tamper alarm indicating that the case has been opened and the second code is complaining about the time and date settings. It may just be that the cmos battery is dead and needs replacing because you will also get a tamper warning if the system thinks the battery has been disconnected. A lithium ion battery is good for about 10 years and this computer came out in 2003. Reboot, go into the setup for the bios, set the correct time and date. If this doesn't do it, you need to replace the battery and then configure date/time.
Nov 06, 2016 | IBM ThinkPad T40 2373 Notebook
How to get manufacturing date of exide battery
On all new batteries there should be a label listing when it was manufactured etc. however there is more commonly a bar code, which you can interpret from here http://www.indpwrbattery.com/Pages/datecode.aspx
hope this helps.
If there is no label, chances are it has fallen off over time. Date Code
May 22, 2015 | Exide Computers & Internet
Vision battery date code
ALL VISION BATTERY MODELS
Date code stamped on top of battery container
X1 X2 X3 X4
Where X1 denotes year of manufacture A = 2001 B = 2002 etc.
X2 denotes month of manufacture A = January B = February etc.
X3 X4 denotes date of month of manufacture
Eg AH27 = battery manufacturing date 27th August, 2001.
Dec 12, 2013 | Exide Chloride Power Station (EXP2000) UPS...
I WANT TO CHECK THE MAUFACTURING DATE OF EXIDE BATTERY MFG CODE 2 BO S.NO. 61610
2B0
2 stands for factory No.2 of Exide
B stands for FEB.month like A-Jan,B-Feb,C-March.....
0 year 2010, eg: 1: 2011,2 : 2012, 9: 2009
Dec 22, 2011 | Exide Chloride Power Station (EXP2000) UPS...
Error code: sec_error_expired_issuer_certificate
This error message usually happens when the date on your computer is incorrect. It is also an indicaton that the CMOS battery is old.. The battery is easy to replace but rarely needed.
Double check your date by right clicking on the date on the right side of the tool bar; adjust date/time
If this doesn't work let me know.
Sep 12, 2010 | Computers & Internet
Ibm thinkpad
The 161 CMOS error means the CMOS/BIOS battery is dead/flat and needs to be replaced.
The 163 CMOS error means the Date and Time could not be updated when you change the Date and Time setting. This is caused by the flat CMOS/BIOS battery.
When you replace the battery with a new one, the BIOS will go back to the default settings, go into to BIOS setting (press F2 when you boot up) and change the Date and Time, then save and exit.
Jul 29, 2009 | IBM Computers & Internet
ERROR CODE C--6C CANON DIGITAL REBEL CAMERA
This code means that your backup (date/time) battery is dead and needs to be replaced. This is a small button battery that maintains date and time settings and other settings when the main battery is removed from the camera. You will need to get a CR2016 battery (button battery). It is located in the battery compartment, in a plastic holder right next to the battery door hinge.The holder should slide out of its socket.
Apr 29, 2008 | Cameras
Laptop battery date code
the code is unknown...ony the computer manufacturer would know... try contacting them.... when in doubt throw it out (for the small things) if your wanting to replace it... go ahead and replace it!
Apr 05, 2008 | Compaq Armada E500 Notebook
Power Patrol Battery 12v 7ah  Rechargeable Sla Sec1075 Power Patrol Logo
508 people viewed this question
Top Power Patrol Home Security Experts
Lawrence Oravetz
Are you a Power Patrol Home Security Expert? Answer questions, earn points and help others
