Question about Craftsman 20 hp 42 in. Deck Yard Tractor
I have a Craftsman917.273323 26 hp Kholer tractor. Drive belt for deck slipped off. Re-routed the belt, but it's not under tension. The second belt for the mandrels is. The 30 am fuse is good. When I engage the electric PTO, it clicks, draws down amps like when it's mowing, but blade don't engage.
    Sergeant:
  • 416 Answers
Recheck the routing
be sure spring lever is engaged ( LEVER on the left side of deck)
disegage then reroute belt re-engage belt tension lever
Posted on Oct 17, 2013
rockitman187
  • 2559 Answers
SOURCE: loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Posted on Apr 04, 2009
  • 12 Answers
SOURCE: how to adjust belt tension 42" raftsman lawn tractor cutting deck
Note: This is about a different mower, but it might be similar enough to yours.  If not, please disregard.  Thanks!
I had a similar issue with our mower, a 2006 Troy-Bilt Pony model 13AN77TG766 (17.5 HP, 42 inch deck): when I pushed the handle down to engage the blades, it took a good ten seconds or so to start the blades turning; even then, they didn't have enough power to cut the grass.  And on any height setting lower than 5, they wouldn't turn at all.
The cause was on page 19 of the manual <URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf>: Figure 17 shows the "PTO" cable attaching to a hole on the edge of the deck idler bracket, but it was shipped from the factory attached to a hole in the middle of the deck idler bracket, about 3 cm (1 in.) closer to the front end of the machine.  I reattached the cable to the original hole, and the belt is now good and tight; the blades engage as soon as I push the handle down.
Now, today, I'm having problems with the belt popping off the right-hand idler (hopefully just needs the deck stabiliser rod adjusting).
Always remember to remove the spark plug wire before you go near the blades; and watch for hot, sharp, and/or pinching surfaces.
Posted on May 19, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
wadembly
  • 462 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
How do I get tension on the belt that drives the deck. The belt goes from the PTO to the deck but is not tight. When you engage the PTO there is not enough tension to drive the deck.
You either have too long a belt or it is routed incorrectly. Do a Google search for you make and model deck belt routing or look up on jackssmallengine.com
Sep 10, 2016 | Garden
I need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
Apr 20, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need drive belt diagram and instructions for replacing the drive belt on a craftsdman dlt 3000 lawn tractor.
Your mower will have a model number like this one:
917.275820 The pictures in the manual below are for the 18.5 - 20 Hp 42 inch deck riding mowers.
It brings up this manual: (3.71 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0411347.pdf
See page 23 under service and adjustments for deck belt routing picture.
Thanks for choosing FixYa,
Kelly
Jul 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a MTD 0675 g Ride on mower, with a 18hp Briggs IC engine. I have recently re bearing'd the cutter deck and fitted a new belt. I cant work out how to adjust the belt-tighten it a little as it slips...
check to see if the belt is in the correct routing, most belt tensioners are able to be fitted with a factory belt in a couple of different routing methods, however only one is right to keep the belt from slipping, look for a belt routing diagram on the mower deck they are the best source fot this information.
Jan 07, 2011 | Garden
My drive belt for my Husqvarna 2754 GLS has slipped off. The mower blades work, but it won't go forward or reverse. It doesn't look broken. I have checked all levers and trany switchs.
sounds like the belt has come off the from the the tension idlers
that are on the clutch brake arm bracket 1 wil be a flat idler and 1 will be a vee idler these 2 place tension on the belt for drive
and when clutched no tension is placed on it
there is also 1 more pulley in the drive line other than pto take off
it is about the middle and is a flat idler
please check website below for part diagram
http://www.partstree.com/parts/?lc=husqvarna&mh=29
select 2754 gls 2008
and go drive system
drive line and belt route will be shown
save a copy fyi
cheers hope it helps
paul
Aug 11, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacing broken drive belt.
look under foot rest on tractor usually there is a diagram under there for belt routing and also sometimes on the mower deck it's self
Jun 24, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
How do I change out the primary belt on a Craftsman 17.5 hp 42" mower? The new belt is around the pulleys but it is very loose.
This belt is easist to install with the deck all the way down. Make sure there are no burrs on any of the pulleys, (will eat up your new belt in short order), also make sure that the 2 drive pulleys for the blades turn freely, (may have grass impacted around them, you may need to remove the 2 guards on top of the deck to clean, (if they do not spin eaisly). Triple check to make sure the belt is properly routed, one mistake and your belt is broken as soon as you engage. With the engine OFF, engage blades to check tension. If the belt is still loose, you likely have it routed incorrectly.
Jun 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
