Vibra power instruction manual sstv 8211 - Audio Players & Recorders
Hi. Do you still have the instruction manual? I bought a machine on Gumtree and only have an exercise manual. Thanks
Posted on Apr 11, 2016
2 Suggested Answers
angelaarcher
SOURCE: vibrapower 8211 instruction manual
i will scan my copy if you like
Posted on Jan 19, 2013
Kenwood ts50
Hi Les, sounds like you have a hardware issue. Usually the power required to transmit is not readily available at your fingertips, so it is stored in capacitors. You may have some bad components in your Kenwood. Time to take it in for a review by a qualified repair tech. Unless you know what's going on inside the case, don't take it apart.
Nov 23, 2013 | Radio Communications
Hi 5800 only vibrate no on
1. By using a scale manually Multitester x1, connect the cables Multitester with positive and negative poles of the Vibra component, if the component is vibrating in a good situation, but if the components do not vibrate Vibra then you need to replace the defective component Vibra.
2. Further examination could be done if the component is not damaged and remained Vibra still using Multitester, connect the cable to the interface component Multiterster Vibra on phone PCB, if there is movement of the needle when it is connected Multitester the path under normal circumstances, otherwise if there is no needle movement means there is a path Multitester end. You can make jumpers system directly from the UI to the component controller IC Vibra. Check also that the positive path from the battery to the Vibra in good condition, if the track is lost then do the path-breaking jumper on you, then the vibration will work again.
exsample image on nokia n95
look
http://1.bp.blogspot.com/_y-JFYukllP4/S4p0DjmWvlI/AAAAAAAACGk/4wjfgVRipqw/s400/vibra%20N95.jpg
Apr 25, 2011 | Nokia 5800 XpressMusic Smartphone
Cellone gprs settings in u.p. east
Manual Bsnl Gprs Settings
Account Name – BSNL WAP
Username –
Password –
Proxy – Enabled/yes
Homepage – http://wap.cellone.in
Proxy and Server address – 10.0.0.10
Proxy and Server Port – 8080
Acces Point Name – gprswest.bsnl.in or mizone
Data bearer – GPRS/ Packetdata
Authentication Type – Normal
May 08, 2010 | i-mate SP5m Smartphone
Gprs settings for nokia 5310 for cellone prepaid in shimla himachal
modem: 5310 xpress musice
pls send gprs and mms setting on my number ; 9439478317
May 03, 2010 | Nokia 5310 Cellular Phone
Operating instruction manual
Here is a link in PDF Format for the Manual. It doesn't offer much help and states that help is available with the Software on a disc that might have been with the package.
http://dl.owneriq.net/9/94de69a0-1868-4742-8211-89df89cf24e6.pdf
Kind regards
Apr 16, 2010 | Microsoft Wireless Optical Desktop Comfort...
I am using sony ericsson w890i when i tried to use for gprs or mobile internet then my phone shows the message "data account does not exists please check your settings" How i can get these data account...
which operatr are u using
to create a gprs settings
goto
Menu >sttings>Connectivity >Internet Settings >Internet profiles> create a new profile
AIRTEL MANUAL GPRS SETTINGS
AIRTEL LIVE
Account Name – Airtel_live
Homepage – http://live.airtelworld.com
Username – Blank
Password – Blank
Proxy – Enabled/yes
Proxy and Server Adress – 100.1.200.99
Accespoint Name – airtelfun.com
Data bearer – GPRS/ Packet Data
MOBILE OFFICE
Account Name – MO
Homepage – http://wap.google.com
Username – Blank
Password – Blank
Proxy – disabled/no
Accespoint Name – airtelgprs.com
Apr 16, 2010 | Sony Ericsson W890i Cellular Phone
Error Code E52 Brother HL1650
In fact the noise/E52 service problem might be easy to fix:
You just have to oil the mirror motor shaft in the laser unit.
Step-by-step instruction:
1 – Remove gently the top cover of the printer ( 4 screws – 2 on top/front + 2 in back/side).
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one.
3 – Remove the laser unit located on top of the printer covered by a steel plate.
To do that:
1 – Unplug (pull) the white flat connector going to the left side of the laser unit.
2 – Unscrew the 3 screws keeping the laser unit in place.
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector.
4 – Squeeze out the laser unit from under the wires (going back and up).
You now have the laser unit outside of the printer.
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back.
2 – Unscrew the 4 screws maintaining the motor section and remove it.
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it.
4 – Pull up the mirror part.
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution.
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess.
7 – Put everything back together.
Jun 21, 2009 | Office Equipment & Supplies
Canon MP 210 gives E5 error and will not print. ??????
To do that:
good luck
Nov 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
316 people viewed this question
 Grubhead
Grubhead
