Question about Frigidaire Refrigerators
New refrig from lowes one week old. now makes ding ding ding ding ding noise 5 times? looked in manual no help
  • Official Brand Answer
  • 4,342 Answers
Hell Bill, I am happy to assist you! Sounds like you are referring to the temperature alarm. When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis or the manufacturer directly.
Posted on Aug 02, 2013
4 Suggested Answers
  • 400 Answers
SOURCE: Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Posted on Mar 20, 2009
heatman101
  • 43501 Answers
SOURCE: refrig will not get cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 25, 2011
  • 195 Answers
SOURCE: Maytag MZD2766GES refrig about 9 years old. No cooling in the refrig or the freezer. Lights work so I know it is getting electricity. Doesn't seem to be making any noise at all. Is there a res
HI.I WOULD CHECK YOUR DEFROST TIMER FIRST.ALI
Posted on Jun 25, 2012
New LG LFXS30766S refrig. Water disp.not putting out full stream of water despite doing what the manual said to do. Old Maytag refrig. I had put full stream of water with no problem.Any suggestions?
LG refrigerators are notorious for junk water valves. IF you have replaced the filter, then your next item is to replaced the water valve. AJU72992603
Jun 22, 2016 | LG Refrigerators
I have a whirlpool refrigerator that is 3 years old the last few weeks it has been cycling on and off a switch or relay seems to be making the noise. Both doors are closed and seem to have a good seal....
your compressor is overloading, this is most likely due to low freon level,
you must have a service person look at the unit...
Please rate/vote this response. thanks
Dec 20, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
(door ajar) and dinging when turning corners to right!! help
check the little rod that sticks out the door jam and make sure its in the proper spot if it got knocked somehow it could be closed but it doesn't know it and will ding
Jul 19, 2009 | 2005 Kia Sorento
Lg cf360 makes dinging noise while on charger
I've had my CF360 for about 2 weeks and I may have run across the same problem you are having. It never happens with the wall charger that came with the phone, but it does occur when I connect using a USB cable from certain computers.
Oddly enough the phone only dings when it is plugged into newer P4, and even one old P3 computer. It does not usually make any dinging noises when I plug it into an older Celeron machine. It does not seem to make a difference if the port is USB1 or USB2, I've tried both.
My first thought was that the newer computers were putting out too much power, but I have sort of come to the conclusion that it may be when they are not putting out enough power. I notice when plugged into the Celeron that the phone will start dinging for a brief period of time if something else starts to draw power, such as the hard drive or the CD drive. Using Windows control panel I have determined that the phone requests 20mA when it plugged in, on all the computers I've tried it on. The micro printing on the supplied wall charger says it outputs 700mA so I have convinced myself that I'm not damaging the phone when it is plugged into the P4 machine, although I'm also probably not getting much of a charge either (I mainly use the USB for data connection, not charging). Even at that I don't leave it on the P4 machine any longer than I need to. The owners manual does have a paragraph or two about low power computers and USB hubs, but never says the phone will ding all the time.
Don't know if I helped, but that is what I've found.
Jul 16, 2009 | LG Cell Phones
Mar 20, 2009 | Refrigerators
Loud noise
When the compressor stops, the movements of the internal components are normally absorbed by the internal spring supports. If a spring breaks, etc., the inner moving part will contact the outer case and give a knocking noise or two when it stops. You can make the compressor (even a new one) do this by giving it a shake. The compressor will most likely run for years this way with no performance problems. It is rather expensive to replace a compressor, (especially for only a noise issue) so most people just live with it or get a new refrig and use their old one as a second refrig in a basement or where ever. Please don't bother to rate this, as anything but a Fix-Ya drops my score.
Dec 31, 2008 | Whirlpool Refrigerators
1996 BUICK REGAL DINGING NOISE
the dinging is from having the turn signal on to long it s a warning I know that sounds strange, mine did the same thing happen to me i made a turn but the turn signal didnt shut off couple mins. later i hear ding ding ding looked at dash turn signal was on shut it off it quit dinging. hope this helps
Dec 08, 2008 | 1996 Buick Regal Olympic Gold
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Frigidaire side/side refri section warm
Oceanrunner, it looks like a couple of things might be going on: One is how much defrosting did you do. If it was a full defrost, you might have too many door openings going on. This causes condensation. Do a full defrost and then be sure the door is closed when not actually getting things in/out. Don't forget to check to see if your condenser coils are clean. If not, clean 'em! That may fix it.
It is possible that your defrost timer is defective but I think not based on your defrost cycle starting. It is possible that the defrost coil is bad. This means that you'll have to access the coil and check if for continuity. Typically, this is located with the coils and below them in the back of the freezer. One wire on each side. Unplug the box...Wiggle 'em to clear any corrosion... Unplug..If you've got a multimeter, check for about 100 ohms between the terminals...You can then turn the unit on and wait. See what happens. If frosting begins, actuate the defrost cycle. (Frosting should be even after about 5 minutes or so across they pipes. If the gas level is low, the frosting will not be even.)
Some cold water units run through the coils. If they get too cold...they freeze. This is caused by low gas or by frosting from other sources. Don't panic: this unit has an extended warranty on the sealed unit...the compressor and all that...for 5 years. That means the gas, too. Call your manufacturer for service.
Nov 28, 2007 | Refrigerators
New Refrigerator Past Warantee Not staying cold
is the fan in the freezer running? if not then the air cant circulate and nothing will cool properly. if is running, is there frost build up on the inside back wall of the freezer? if so you have a defrost problem. if no frost on the back and the fan is running, remove the back panel inside the freezer and make sure all of the silver coils have light frost on them. if only part of them are frosted get out your manual and look at the warranty section. then seal system may have a 5 year warranty. if it does then call sear for warranty service. if the coils only have partial frost and its not under a 5 year warranty buy a new frig. because repair will cost more than its worth
Nov 26, 2007 | Refrigerators
Refrigerators Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
