Engine misses when under power, is there a additive to correct this or whats issue
Check spark plug and leads
Posted on Aug 01, 2013
Got a bad miss
The most common problem for this symptom, is a faulty cap and rotor. When was the last tune-up? There are other reasons for a bad miss though. You may have another ignition related issue. Run a compression test first, check the battery and the charging system, look for loose or damaged wiring in the engine compartment. From there you can inspect the ignition system, and the fuel system. If there is any additional information that you can think of, write back. Maybe you noticed a light on the gauge cluster that was never on or flashing before. Good luck.
Apr 02, 2014 | 1995 GMC Sierra
Hi-Speed Miss under load on Park Avenues - Both Ultra and Non-supercharged
Dear sir/madam,
I think he crank sensor is defective, or installed wrong. The cam sensor controls fuel injector timing and can cause sputtering and hesitation. The timing must be correct for the injector to fire when the intake valve is opening. Check for any scratch marks on the cam sensor. In addition, check the cam interrupter magnet and be sure it in place and not damaged.
The ECM sends a 5-volt reference signal to the CTS sensor. As temperature changes in the coolant, the electrical resistance of the CTS sensor also changes. The best way to test this sensor is with a scanner. When the engine is cold, engine coolant temperature should measure near the same as the ambient temp. Another way to test the CTS sensor is to measure voltage from the time the engine is started, until it warms up. Record the voltage changes as the engine warms up to operating temp. i.e. 120, 140, 160 & 180. You should see close to the full range of voltage (5.0-1.0V) during this test. If it does not change from what you first measured cold, replace the sensor!
thanks
good luck
"Don't forget to rate the solution"
Jul 27, 2008 | 1999 Buick Park Avenue
1992 firebird. 305 engine after warm up starts missing under acceleration
could be a overheating issue the gague may register that it is at correct temperature but maybe just a few degrees warm causing what is called vapor lock where the gas is getting to warm and is evaporating before it gets into intake worked on same car a few years back and it turned out that they removed the botom of fan shroud causing this particular problem if your shroud is all there also check any lines tubes or hoses that lead into your air intake.also check your plug wires if rubbing on manifold when gets hot could cause a short in spark causing misfire.any check engine lights appear in the dash?
Mar 23, 2014 | 1992 Pontiac Firebird
What happens if the oil dip stick is missing for 2 months
A missing oil dipstick will not cause any issues with your engine.
Jul 22, 2013 | 2007 Saturn Vue
2001 rodeo motor issues
No vehicle requires any additives for any reason
If coolant is leaving, it has to go somewhere,like
out the head gasket & into the exhaust
Do a combustion gas test & cylinder leak down test,
& check the timing belt & water pump for leaks
Apr 06, 2013 | 2001 Isuzu Rodeo
Missing multimedia audio controller ASUS system Pentium D Windows XP
If you are missing your audio controller .
  • you can try running a scan to update your Install Audio Controller or then include additional steps to manually correct the issue.
Mar 01, 2010 | Intel ESS ES1868F Sound Card
I have a 4.3 and 5 speed 4x4, the engine will miss under load, new gas tank and sending unit installed, looking at replacing fuel filter, any other ideas?
If you are missing, due to a cylinder failure, the fuel filter, sending unit and all of that affect all of the engine. If you get a "skip" under a load, you have a cylinder issue. You need to determine what cylinder. Try to throttle it up while applying the brake to keep it from moving in drive to see if you can get it to skip.
If it does, look at spark plugs to see if you can see what cylinder looks different.
Or...while someone is "power braking" and it's missing, remove a spark plug wire one at a time to see if the condition changes. If it doesn't change, that is your bad cylinder.
Then you need to determine if it's fuel, or spark that is the problem.
(Injector bad, or plug, or plug wire.)
Jan 11, 2010 | 1995 GMC Sierra
1997 stock c/v carburetors. Getting gas in air cleaner
There's the issue. You're over-cammed and over/under over fueled, but under exhausted and under compressed. You've miss-matched the engine. In my experience, overcamming the stock piston and jug doesn't do a bit of good. You don't have enough compression to utize the additional air and fuel. You can try running a better pipe, but in my opinion, unless you bump her up to 8-1 compression, that cam set is hurting, not helping.
Apr 05, 2009 | 2006 Enfield Bullet Electra
87 4Runner 22RE problem
Replace the number one injector; it is sticking open.
Oct 07, 2008 | 1985 Toyota Pickup
Card reader
NTLDR is missing Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it.
Windows device manager base system device under other devices. This occurs when the drivers for the card reader on your laptop or computer is not properly installed. To correct this issue either locate the drivers on .
Good Luck, Read and foloow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Dell Latitude LS500 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
