Question about Boating
1991 8hp evinrude, E8REIA
My drive shaft has excessive pitting from salt water use. The lip seal no longer functions due to the pitting. I can't find the drive shaft from any retailers or salvage yards( 15" driveshaft) Do you know of any effective repairs?
    Sergeant:
  • 456 Answers
Will have to get it re hard chromed
Posted on Oct 22, 2013
I have a 1973 evinrude 25 hp motor that does not circulate water through. I took out the water pump and the rubber propeller is in good shape.Any other ideas?
look at the prop part closely
see if the water flushes fully through the block without the pump fitted
seals
blocked gauze/water pick up fouled
i know these corrode even with the best of flushing
make sure the pump drive shaft is spinning with the base of the motor sometimes the shaft spline will splinter or break
Aug 04, 2016 | Boating
I need to replace the prop seal on a 1987 50hp evinrude
you need to disassemble your gear case, remove the prop shaft, and then replace the seals. however, if you are careful, it is possible to hook them out with a screwdriver and reinstall them but you need to be carefull not to damage the prop shaft . if you do the new seals will leak. also be sure to put some sealer around the outside of the seals before installing them and a little bit of grease on the inside lips.
Nov 15, 2009 | Boating
HOW DO YOU REPLACE THE REAR TRANSMISSON SEAL IN A FORD 2005 F250
Place vehicle on Jack stands, remove drive-shaft, remove old seal with a Seal Puller, place lubricant on inner lip of new seal, install new Seal carefully & do not damage the Output Shaft of Transmission with hammer etc. , reinstall Drive-shaft, lower vehicle, check fluid level, road test vehicle
Oct 28, 2009 | 2005 Ford F 250 Super Duty
Over presure inside the engine so the distributor oil seal pushes by oil and spill,i already replace the valve cover but its the same.what possible solution can beat it?
on the dist shaft there is an oring that seals at the engine if you remove your cap and then mark your dist so that you dont change the timing ,then remove the distributor and you will see the oring on the dist shaft ,replace it ,they get flat and hard and wont seal any longer ,good luck !
Aug 08, 2009 | 1996 Honda Accord
Hi there need to replace the final drive seal on a 450crf x,is this straight forward? or do I need someone elses hands.Appreciate any info.
It is a one man job. Just remove the sprocket bolt, washer, sprocket and collar. Clean the area around the shaft and clean the shaft, then pry the old seal out any way you can. Put the new seal in straight (not at an angle). The seal should be flush with the case surface. Put some grease on the inner lips of the seal before mounting.
Top rating due on this answer! Thanks Hugh!
Apr 22, 2009 | 2005 Honda CRF 450 X
Leaking Rear Transmission Seal
Did you use a motorcraft seal? aftermarket seals are not as good, the factory seal is double lipped as far as I remember.
Nov 30, 2008 | 2000 Mercury Sable
2000 Mercury Grand Marquis
I was given an solution by emissionwiz from the fixya site.
Thanks,
GGBMDB
Nov 30, 2008 | 2000 Mercury Grand Marquis
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
