Question about Craftsman Garden
I have a craftsman with a kohler 26 hp engine and the fuse blows when the key is turned on I replaced the rectifier regulator already and it still does the same thing If I unplug this the fuse does not blow what else could it be?
    Novelist:
  • 212 Answers
Is it when key is turned on or start? You have a power shorted to ground somewhere. Unfortunately, they are difficult to diagnose. I would start at battery and check for wires rubbed through to frame of unit. From there to key switch, etc. Sorry for vague response, but these are tricky. I had this happen to mine also. Mice nested under the engine cover and chewed through wires and grounded unit out.
Posted on Aug 02, 2013
dennymulford
  • 1055 Answers
SOURCE: blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Posted on Mar 18, 2009
  • 57 Answers
SOURCE: 2000 with kohler engine starter wont turn engine over.
Try adjusting the valves. Not an uncommon problem.
Posted on May 15, 2009
  • 109 Answers
SOURCE: fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Posted on Jun 29, 2009
mowerman1857
  • 389 Answers
SOURCE: Craftsman II LT 4000 MOD # 917-255691 with a
Check the wire from the ignition switch to the small terminal on your solenoid with a volt meter to make sure you are getting current to the solenoid. If not try a "jumper wire" connected to the same terminals and see if it now cranks. If it does, replace the wire
Posted on Sep 14, 2009
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
I have a craftsman 26 hp kohler enginewhy does keep dying on me seems to be no fuel in the filter
Sounds like a dirty carb. Is there a cup on the bottom of the carb with a nut on the bottom? If so take it off and clean it out as well as blow the orffice out thats on the bolt you take out.
Jul 27, 2014 | Craftsman Kohler Courage 26 hp 54" Garden...
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
I have a 2004 r6. i replace the rectifier/regulator yesterday. When i turn the key to on position. My ignition fuse keep blowing. Is my starter relay bad???
I HAVE YZF R6 2003, WHEN I START THE ENGINE AFTER ALMOST 5 MINUTE RECTIFIER REGULATOR OVER HEATING AND DAMAGE CONECTION
Jul 16, 2011 | 2004 Yamaha YZF-R6
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Apr 04, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsmen tractor needs engine.
http://www.smallenginewarehouse.com/
This will direct you to all kinds of engines. You pick the one that fits you tractor.
If it is a 26 HP Kohler engine you will spend about $1,500.00 for a new one.
You may want to consider 2 options.
Finding a used engine or replacing the tractor.
Please let me know what you find
Feb 06, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
