Question about Eureka 402A Bagless Upright Vacuum
How do i remove cover of eureka 402 upright to clean brush?
  • Carol Louthan Aug 04, 2013
    I figured it out. You pull the front bottom piece forward and then pull up on the cover. It is head on with three tabs, be careful not to break the tabs, they seem fairly strong though.
  • Eureka Master
  • 18,424 Answers
yeroc
  • 397 Answers
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Posted on Jan 20, 2008
SOURCE: Broken on/off switch
I have the same vacuum and the on/off switch wasn't working any longer so I took the cover off to find out that the wiring got so hot that it melted through the wire coating and plastic frame.
Posted on Aug 28, 2008
  • 55 Answers
SOURCE: Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Posted on Nov 24, 2008
  • 5 Answers
SOURCE: eureka 4870 roller only spins in upright
if the belt has been slipping it may have pollished the moteror brush shaft and it just slips. take a small piece of sand paper or enery cloth and ruffen up the shaft to give it some grip.
if the metal shaft of the motor has been heated up due to slippage it will take some doing to ruffun it as the shaft will be hardend due to heat
Posted on May 14, 2009
  • 21 Answers
SOURCE: I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Posted on Jul 23, 2009
Eureka Optima 431x Belt replacement
Not sure if this is any good but here is a link to a youtube video showing how to remove the cover and change the brush and belt.
https://www.youtube.com/watch?v=JxoHDvr1ZJI
Apr 07, 2013 | Eureka 431A Optima Bagless Upright Vacuum
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
How do you replace the belt on the Eureka 4495A Upright?
hi there,
on this model there are 2 screws on the top of the unit just above the brush as you are looking at it.
Remove the 2 screws there and the top cover should come off.
There is also a black and yellow sticker under the top cover near the belt that describes in detail on how to change the belt there. Once that is done line up the cover and put the screws back in.
Good luck .
Nov 19, 2010 | Eureka 4495A Bagless Upright Vacuum
How can I disassemble the Eureka Altima Brush Roll (#60844-7) for cleaning? Thank you, Jerry in Irving, TX
You can remove the two screws in the top cover above the roller. Then lift off the top cover exposing the roller. You can then pull the roller out, and clean out the cradles that hold the end caps. The square end caps can also be pulled off the bearings at the ends of the rollers. I had a lot of stuff wrapped around mine creating a lot of drag, but the bearings were just fine once everything got cleaned out. Just remember which end cap is which, cause they're different for each end.
Oct 05, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
I have a Eureka Altima and not sure how to change the belt?
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
new belt around motor shaft and
brush roll
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Bravo! 7.0 vaccum cleaner, how do I change the belt
Turn the vac over so the brush is facing up.. There is a cover plate that surrounds the brush.. Take the screws out and remove the cover plate.. Pull up on the side of the brush that the belt is on.. Replace the belt.. The belt goes around the metal shaft and the brush.. Push the brush back in place.. It might be a bit tough going in because the belt causes some tension.. Put the cover plate and screws back in..
Good luck ! Please don’t forget to rate well ;o)
Aug 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
Mar 08, 2009 | Eureka 402A Bagless Upright Vacuum
Eukerka lite speed
There are 2 screws on the top cover, remove those and the cover comes off, then you can get to the brush roll and belt. Inspect the brush roll, make sure the ends turn freely, if not, then replace it also.
Jun 08, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Eureka bagless whirlwing lite vacuum cleaner
On the top cover, one on each side will be a screw, take those out and the top cover should come off. While you have it off, check the brush roll to make sure it is turning freely, and replace the belt, they stretch after a short time and will give you problems.
Apr 20, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Eureka 402A Bagless Upright Vacuum Logo
159 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
