Question about Broderbund PrintMaster Platinum 18 for PC
CHANGE SIG.FILE TO JPG - Broderbund PrintMaster Platinum 18 for PC
How to add wallpaper to flash drive background?
First you need to create a desktop.ini file in your flash drive.
Open Notepad and click Save as.
Then set file name to desktop.ini and change Save as type to All files.
Click Save as.
Place your wallpaper in the flash drive. It should be a ".jpg" file
Open desktop.ini file from your flash drive. Copy and paste below code to it.
Last line of the code, you can see "IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper name.
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
Save your file. Unplugged the flash drive from PC and plug it again. That's it.
If you need more information
Visit SmartUSB.net
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change your flash drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Jul 25, 2012 | Electronics - Others
Tip
How to hide files in a jpg photo
1) Take two files -
one which you want to hide and another will be the jpg image(of any size and dimension)to hide that file
If you want to hide multiple files in one jpeg image, just zip them into one file
2) To make the process easy, Copy the above two files to the C:
3) Now open the command prompt (Go to start, Click "RUN" and type "cmd").
4) get to the root by typing cd\ or you can give the path name where the files are located
5) Now type the following command:
copy /b imagename.jpg + filetohide.ext new_image.jpg
6) Now a new file new_image.jpg will be created
7) Double click on the file and it will open the image which you used to hide the secret file
8) To access the hidden file simply change the extension from jpg to orignal extension of the hidden file,
Example: I took an image filename "myphoto.jpg"
I wanted to hide some important word documents so I zipped all the word files and created a zip file "word.zip"
Then copied both "myphoto.jpg" and "word.zip" to c:
Opened the command prompt
Typed the command: copy /b myphoto.jpg + word.zip new_image.jpg
Now I have a new file "new_image.jpg" in C:
When I double click on the new file it shows me the image of "myphoto.jpg"
If I change the extension of new_image.jpg to new_image.zip I can extract the contents of the .zip file
ENJOY !
ENJOY !
on Dec 03, 2009 | Computers & Internet
DIFFERENCE BETWEEN JPG..AND RAW??????
The RAW file contains all the data as captured by the sensor. The JPG is processed, applying the white balance, sharpening, contrast, and other settings as set on the camera. You can change the settings on a RAW file and produce new JPG files at will. If you're going to be doing much work with the picture, you're much better off starting from the RAW.
An imperfect analogy is to think of the RAW file as the negative and the JPG as a print produced from the negative.
Nov 30, 2010 | Cameras
Internet photos download as bitmaps instead of jpg's
First open Microsoft Paint by going to Start, All Programs, Accessories and then Paint
Now open the BMP file in Paint. Now all you have to do to save the file in JPG format is to simple do a Save As. Change the File Type drop down menu to JPG and click Save
Jun 11, 2010 | Compaq Presario 5000 PC Desktop
I don't want photoshop to launch when I open a pdf or a jpg
Well, here's the simple steps, Right-click on any jpg/jpeg file, select "properties" click "change" and select "Windows Picture and Fax Viewer" "Ok" "Apply" "Ok". Sometimes you'll need to browse the application, but in your case, i hope "windows picture and fax viewer" is right there. Same thing with the pdf, but you'll only need to open a pdf reader like "Adobe Reader" or "Fixit Reader". Good luck. Thank you for using FixYa.
Jun 08, 2010 | Adobe Photoshop CS2 for PC
Hi there!
Try saving the file as "save as" then look for the option for the dropdown menu to save as another file format!
Hope it helps!
Feb 24, 2010 | Broderbund PrintMaster Platinum Version 18
Media Center file types
Yes, file extensions, .gif, .bitmap, .jpg are case sensitive. Just like if you tried to save a word document as .DOC then the file would look like test.DOC.doc. Change case and it will be fine.
Mar 02, 2009 | Microsoft Windows Vista Home Premium with...
I create a graphic signatue as an html file but when I insert it in a created email it arrives in the attachment line and has to be opened as a separate file. When it is created as a signature in the...
try it like this:
Alt+Print Screen your signature, and paste it into paint. Crop the edges so that your signature is all that is seen and save it as something like c:\sig.jpg.
Then edit your html file to contain something like this:
<html>
<body>
<img src="c:\sig.jpg" height=80 width=80><br>
<b>hoot776</b>
</body>
</html>
Jul 16, 2008 | Computers & Internet
Sig file
SIG File Extension
File Type Signature File Category Text Files Common? No File Description Small text file that can be automatically attached to the end of e-mail messages; usually includes the sender's name and e-mail address; for work e-mail, the signature may also include the name of the person's company, the person's titile, and contact phone numbers; some people choose to include a quote or Bible verse in their e-mail signature.
Most e-mail programs support multiple signature files; they can usually be selected from within the create new message window. Program(s) that open sig files mac.gif Mac OS tri.gif QUALCOMM Eudora Pro
windows.gif Windows tri.gif QUALCOMM Eudora Pro
tri.gif Microsoft Outlook or Outlook Express
Nov 06, 2007 | Microsoft Office Outlook 2003 for PC
Broderbund PrintMaster Platinum 18 for PC Logo
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
