Question about kawasaki Garden
How do you get the crankshaft pulley off a Kawasiki FD590V engine?
4 Suggested Answers
  • 393 Answers
SOURCE: Crankshaft pulley (vibration damper) moved forward.
the pulley is also a dampener often times they seperate from each other. replace pulley/dampener.
Posted on Nov 18, 2008
cincinaty5
  • 132 Answers
SOURCE: to remove crankshaft pulley
use a three arm puller to remove this , useing a prybar on the flywheel will cause teeth damage and make for more repairs .
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: my 1986 toyota Mr2 has
yes if its in the front but it more like the back one you might just drop the oil pan and do it if you have room to get the iol pan down
Posted on Mar 29, 2011
How do you remove the crankshaft dumper pully?
Published: 11-May-2011
Engine - V8 4.4L Petrol - Crankshaft Pulley
In-vehicle Repair
Special Tool(s)
Holding Tool Crankshaft Pulley
303-893(LRT-12-080)
Adapter
303-191-03
Bolts and spacers
303-191-04
Remover, crankshaft pulley
303-588
Remover, crankshaft seal
303-D121
Installer, crankshaft seal
303-1100
Adapter - Crankshaft seal installer
303-1100-01 Removal
  1. Disconnect the battery ground cable.
    For additional information, refer to: Specifications (414-00 Battery and Charging System - General Information, Specifications).
  1. WARNING: Do not work on or under a vehicle supported only by a jack. Always support the vehicle on safety stands. Raise and support the vehicle.
  1. Remove the accessory drive belt.
    For additional information, refer to: Accessory Drive Belt (303-05B Accessory Drive - V8 4.4L Petrol, Removal and Installation).
  1. Remove the cooling fan shroud.
    • Release 2 clips from the cooling fan lower shroud.
    • Release and remove the cooling fan lower shroud from the cooling pack.
  1. Using the special tools, retain the crankshaft pulley.
  1. CAUTION: Under no circumstances should the crankshaft setting peg, 303-645, be used in the following operations, to restrain the crankshaft. NOTE: The crankshaft pulley retaining bolt will be very tight.
    Remove the crankshaft pulley retaining bolt.
    • Discard the bolt.
  1. Remove the special tools.
  1. Using the special tools, remove the crankshaft pulley.
    • Collect the locking ring.
  1. Remove the special tools from the crankshaft pulley.
  1. Using the special tool, remove the crankshaft front seal.
    • Remove the outer section of the seal.
    • Repeat the process to remove the inner section of seal.
  1. Check the crankshaft damper pulley and locking ring for damage.
Installation
  1. Clean all the crankshaft pulley mating faces.
  1. Using the special tools, install the crankshaft front seal.
    • Lubricate the seal with clean engine oil.
    • Use the discarded crankshaft bolt with the service tool.
  1. Install the crankshaft pulley.
  1. Install the crankshaft pulley locking ring.
  1. CAUTION: The screw thread in the crankshaft pulley must be cleaned out before installing a new crankshaft pulley bolt. Install, but do not tighten, the new crankshaft pulley bolt.
  1. CAUTION: Under no circumstances should the crankshaft setting peg, 303-645, be used in the following operations, to restrain the crankshaft. Using the special tools, retain the crankshaft pulley.
    • Tighten the crankshaft pulley bolt to 380 Nm (280 lb.ft).
  1. Install the cooling fan lower shroud.
  1. Install the accessory drive belt.
  1. Connect the battery ground cable.
Jan 27, 2016 | 2006 Land Rover Range Rover Sport
1996 toyota camry 2.2 5s- too manny timing marks crank shaft,cam shaft and cam shaft gears
Hi there:I dont have this diagram for 2S-ELC, 3S-FE and 5S-FE Engines, but pay attention at this...
To install:
  1. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  2. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  3. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly.
Remove any oil or water on the idler pulley and keep it clean.
  1. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  2. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys.
If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  1. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  2. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  3. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  4. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  5. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt.
On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  1. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  2. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  3. Install the timing belt and check the valve timing as follows:
    1. Align the matchmarks that you made previously, and install the timing belt onto the camshaft pulley.
    2. Loosen the No. 1 idler pulley set bolt 1 / 2 turn.
    3. Turn the crankshaft pulley two complete revolutions TDC to TDC. ALWAYS turn the crankshaft CLOCKWISE. Check that the pulleys are still in alignment with the timing marks.
    4. Tighten the No. 1 idler pulley set bolt to 31 ft. lbs. (42 Nm).
    5. Make sure there is belt tension between the crankshaft and camshaft timing pulleys.
  4. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  5. Install the spark plugs.
  6. Install the right mounting insulator with bracket. Tighten the bracket bolts to 38 ft. lbs. (52 Nm), insulator nuts to 38 ft. lbs. (52 Nm) and thru-bolt to 52 ft. lbs. (71 Nm). On the 5S-FE, install the No. 2 engine mount bracket and tighten to 38 ft. lbs. (52 Nm); install the control rod and tighten the bolts to 47 ft. lbs. (64 Nm).
  7. Lower the engine.
  8. On 3S-FE and 5S-FE engines, install the alternator and alternator bracket. On 2S-ELC engines, install the power steering reservoir tank.
  9. Install the drive belt and adjust the tension.
  10. Install the cruise control actuator with bracket.
  11. Install the fender apron seal and right engine under cover.
  12. Install the right front wheel.
Hope this helps.
Jun 12, 2012 | Toyota Cars & Trucks
How can i remove timing belt on 2005 kia sedona
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable Engine cover Accessory drive belts Idler pulley Crankshaft pulley Power steering pump pulley Belt tensioner pulley Upper and lower timing belt covers
  4. Support the engine with a floor jack and remove the engine mount.
  5. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
    Fig. Timing belt routing and timing marks-3.5L Engine
  6. Remove or disconnect the following:
    Auto tensioner Timing belt
    Fig. Timing belt and related components-3.5L Engine
To install:
  1. Ensure that the engine is set to Top Dead Center (TDC).
  2. Prepare the auto tensioner for installation by compressing it in a vise and installing a retaining pin.
  3. Install the timing belt in the following order:
    1. Crankshaft sprocket
    2. Idler pulley
    3. Left bank exhaust camshaft sprocket
    4. Left bank intake camshaft sprocket
    5. Water pump pulley
    6. Right bank intake camshaft sprocket
    7. Right bank exhaust camshaft sprocket
    8. Tensioner pulley
  4. Install the auto tensioner. Do not remove the retaining pin at this time.
  5. Check that the crankshaft and camshaft timing marks are aligned correctly.
  6. Rotate the crankshaft 1 / 4 turn Counterclockwise .
  7. Rotate the crankshaft 1 / 4 turn Clockwise to return the engine to TDC.
  8. Loosen the tensioner pulley center bolt.
  9. Apply 44 inch lbs. (5 Nm) torque to the tensioner pulley as shown and tighten the center bolt to 32-41 ft. lbs. (43-55 Nm).
    Fig. Adjusting the tensioner pulley-3.5L Engine
  10. Remove the auto tensioner retaining pin.
  11. Rotate the crankshaft 2 revolutions Clockwise , then wait 5 minutes for the auto tensioner to adjust.
  12. Measure the auto tensioner rod as shown. If the measurement is not 3.8-4.5 mm, then repeat the belt tensioning procedure.
    Fig. Measuring the auto tensioner rod-3.5L Engine
  13. When the auto tensioner measurement is correct, install or connect the following:
    Engine mount Upper and lower timing belt covers Belt tensioner pulley Power steering pump pulley Crankshaft pulley Idler pulley Accessory drive belts Engine cover Negative battery cable
  14. Reprogram the radio anti theft codes
May 08, 2012 | 2005 Kia Sedona LX
1997 acura tl crankshaft spinning freely, is this normal? Just replaced a/c compressor and the pulley is turning real slow. Belt is not slipping. The crankshaft pulley and a/c pulley/belt rotate normally...
CHECK SEE IF CRANK SHAFT PULLEY BOLTS LOOSE.IF CRANKSHAFT PULLEY LONG BOLT TORQUE IS FOR 130 FT LBS FOR 1.8L ENGINE. IF YOU HAVE THESE ENGINES CRANKSHAFT BOLT TORQUE IS 174 - 181 FT LBS ENGINES ARE 3.0L 3.2L 3.5L 2.3L 2.5L IF CRANKSHAFT PULLEY BOLT IS TIGHT.THE CRANKSHAFT PULLEY ITSELF BROKEN NEED REPLACING.
Sep 05, 2011 | 1997 Acura TL Series
I need to know how to change a timing belt on a 2002 Kia Sendona
  1. Record the radio anti theft code data.
  2. Remove or disconnect the following:
  3. Support the engine with a floor jack and remove the engine mount.
  4. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
  5. Remove or disconnect the following:
To install:
    2. Idler pulley
    8. Tensioner pulley
  14. Reprogram the radio anti theft codes.
Feb 06, 2011 | 2002 Kia Sedona
Which way do u turn the harmonic balancer bolt to remove it
gas engine :counter clock wise use penetrating oil let soak lefty loosey Diesel Engines
The 2.2L diesel engine utilizes an exposed crankshaft pulley and a hidden crankshaft timing pulley/damper. The following procedure may be used to remove the exposed crankshaft pulley.
  1. Disconnect the negative battery cable.
  2. Loosen and remove the accessory drive belts.
  3. Turn the crankshaft pulley to align the timing mark with the engine pointer. This should be done if any further procedures are being performed which might disturb valve timing.
  4. Remove the retaining bolts, then remove the crankshaft pulley.
To install:
  1. Align and install the crankshaft pulley.
  2. Install the retaining bolts, then tighten to 10-17 ft. lbs. (14-23 Nm).
  3. Install the accessory drive belts, then properly adjust their tension.
  4. Connect the negative battery cable.
Dec 12, 2010 | 1994 Isuzu Rodeo
Procedure in changing timing belt
Timing Belt and Sprockets REMOVAL & INSTALLATION 2S-ELC, 3S-FE and 5S-FE Engines
  1. Remove the timing belt covers as previously detailed.
  2. Raise the engine just enough to remove the weight from the engine mount on the right side.
  3. Remove the thru-bolt, two nuts, and right hand mounting insulator.
  4. Remove the retaining bolts and remove the right hand mounting bracket (from the side the alternator was removed from).
  5. Remove the timing belt and timing belt guide. If the timing belt is to be reused, draw a directional arrow on the timing belt in the direction of engine rotation (clockwise) and place matchmarks on the timing belt and crankshaft gear.
  6. Remove the bolt retaining the No. 1 idler pulley and tension spring.
  7. Remove the No. 2 idler pulley.
  8. Remove the crankshaft timing gear , if it can not be removed by hand, use two flat bladed tools to pry it off. Make sure to position shop rags to prevent damages to the components.
  9. Remove the nut retaining the oil pump pulley. To install:
  10. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  11. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  12. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly. NOTE: Remove any oil or water on the idler pulley and keep it clean.
  13. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  14. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys. NOTE: If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  15. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  16. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  17. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  18. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  19. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt. NOTE: On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  20. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  21. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  22. Install the timing belt and check the valve timing as follows:
    2. Loosen the No. 1 idler pulley set bolt 1⁄2 turn.
  23. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  24. Install the spark plugs.
  25. The remainder of installation is the reverse of removal. Tighten each component to specifications.
Aug 04, 2010 | 1996 Toyota Camry
I would like to know where the crankshaft gasket is? I have a 1994 dodge spirit, a 6 cyl. How hard is it for me to replace the gasket?
3.3L and 3.8L Engines
  1. Raise and safely support the front of the vehicle on jackstands.
  2. Remove the right front wheel and inner splash shield.
  3. Remove the accessory drive belt from the engine.
  4. Remove the center bolt of the crankshaft pulley.
  5. Using a claw-type gear puller, remove the crankshaft pulley from the crankshaft. When using the puller, make certain that the claws are situated on the inner section of the pulley. If the claws are used on the outer section of the pulley, the pulley will be damaged.
  6. Use tool C-4991 or the equivalent to remove the oil seal from the timing chain cover. Make certain not to damage the crankshaft seal surface of the cover. Fig. 10: Use a claw-type gear puller to remove the crankshaft pulley/damper — 3.3L and 3.8L engines 86723231.gif
    Fig. 11: Use the seal remover tool C-4991 to remove the crankshaft oil seal — 3.3L and 3.8L engines 86723230.gif
    To install:
  7. Install the new seal by using tool C-4992 or the equivalent. Place the seal into the opening with the seal spring towards the inside of the engine. Install the seal until flush with the cover.
  8. To install the crankshaft pulley to the crankshaft a 5.9 in. (150mm) long bolt, a thrust bearing and washer, and plate L-4524 or equivalent.
    1. Tap the crankshaft pulley onto the crankshaft with a rubber or plastic mallet making sure to hit the pulley on the center portion.
    2. Once the pulley is started onto the crankshaft, install a nut the thrust bearing and washer, and the plate L-4524 onto the bolt.
    3. Thread the bolt into the end of the crankshaft and screw it in at least 2 or 3 complete turns.
    4. Tighten down on the nut on the bolt to slowly press the pulley onto the crankshaft until completely seated.
    5. Remove the bolt, nut, washer and thrust bearing, and plate L-4524 from the crankshaft. Fig. 12: Installing the crankshaft pulley — 3.3L and 3.8L engines 86723229.gif
  9. Install the center crankshaft pulley bolt and tighten it to 40 ft. lbs. (54 Nm).
  10. Install the accessory drive belt and tighten by following the instructions in Section 1.
  11. Install the splash shield and front wheel.
  12. Lower the vehicle to the ground.
Jul 16, 2010 | 1994 Dodge Spirit
Valve tapping in Kaw FD590V
I found a maual online at:
www.scribd.com/doc/8567778/Kawasaki-Gas-Engines
Jun 15, 2009 | kawasaki Full Suspension Mountain Bike Men
Nov 18, 2008 | 1993 Jeep Grand Cherokee
Garden Logo
32 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
