Question about Car Audio & Video
Hi. Philips Mini HiFi system model FWM377, has a fault with the CD/USB sections. On first switch on and before pressing any other buttons, by pressing tuner, the radio works fine, and similarly with the tape/Aux section. So no problem with main amplifier etc. Also in this state the disk carrier will rotate and be ejected. However, if any other button is pressed to do with either the CD player or the usb button or the standby/Aux/eco button. The system freezes and the display is locked on what it was before pressing one of these buttons, and nothing works, none of the buttons respond or have any effect. This can be reset by turning the mains power off and on again. If you press the standby/Aux/Eco button first, the system locks straight away and no buttons respond. If after re-setting (mains off and on) the Aux/Standby/eco button is pressed and held for 5 seconds the eco light comes on and usually immediately goes off. Any suggestions about a solution to this problem.? Thank you Carey
techman
  • 3130 Answers
SOURCE: Satellite No Longer An Option on My Kenwood KDC-MP228
Your going to need to pull off the battery cable for about 2 to 5 minutes and see if this will reset the radio. Good Luck
Posted on Mar 23, 2007
pnevai
  • 48 Answers
SOURCE: JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Posted on Jun 29, 2007
KaeZoo
  • 156 Answers
SOURCE: power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Posted on Aug 11, 2007
ampman
  • 98 Answers
SOURCE: JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
Posted on Sep 13, 2007
SOURCE: I can't use my ipod.. pressed SCR and only tuner and standby is displayed
Yes i had a very similar problem.
I have the MP-235. I could not edit my clock, my subwoofer settings werent active, and I could not switch to AUX.
If you have these problems, you have to hold down the menu button (bass boost) to enter the menu. then scroll around, turn AUX on, change the clock, etc etc.
You turn demo mode off the same way. Kinda silly how they have it all set up.
Hope that helps anyone in the future. i just wasted 3 hrs with this crap!
Posted on Dec 27, 2007
Philips micro hifi system mc230 cd door will not open
Could be that the door drive belt (if it uses one) has come off.
Feb 25, 2016 | Philips Audio Players & Recorders
Philips mini hi-fi system fwd796 dvd keep restarting
It sounds that the DVD Disc is not loading properly, and does not get seated inside the mechanism. This is purely a mechanical fault. Contact any service technician. The set should have to disassemble to take out the mechanism, and this is a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 09, 2014 | Philips FWD570 DVD MINI-HIFI SYSTEM FOR...
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
Need a remote for a PHILIPS Mini HiFi System
Try E bay as the remote is considered an accessory and are one of the first product to run out of supply. There is always the possibility that a person will sell one from either a shipping damaged unit or one that could not be repaired but the remote still works.
Jun 02, 2012 | Audio Players & Recorders
Manual for fwm377 mp3mini hifi system
Hi!
User Manual
Quick Start Guide
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 29, 2011 | Audio Players & Recorders
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
Car Audio & Video Logo
142 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
