Static timing on mazda f8 engine and tappet clearances on intake and exhaust valves.
  • 3,799 Answers
Read your workshop manual. And the headings you are asking question in.
Posted on Aug 01, 2013
Hey there I need the exhaust and Intake(valve) clearance for a komatsu 300-6 please
note Perform the valve clearance check and adjustment at the engine cold state. 1.Remove all of the ignition coils. 2.Remove the cylinder head cover.
caution Turn the crankshaft always clockwise. 3.Turn the crankshaft clockwise, and align the timing mark on the exhaust camshaft sprocket against the upper face of the cylinder head as shown in Figure. Therefore, No.1 cylinder goes to the compression top dead center. 4.Using a thickness gauge, measure the valve clearance with the arrow shown in Figure. If deviated from the standard value, make note for the valve clearance.
Standard value:
    Intake valve 0.20 ± 0.03 mm (0.008 ± 0.0012 inch)
    Exhaust valve 0.30 ± 0.03 mm (0.012 ± 0.0012 inch)
5.Turn the crankshaft clockwise 360 degrees, and put the timing mark on the exhaust camshaft sprocket in position shown in Figure. Therefore, No. 4 cylinder goes to the compression top dead center. 6.Check the valve clearance with the arrow shown in Figure. In the same procedure as 4.
7.If the valve clearance is deviated from the standard value, remove the camshaft and the valve tappet. For the camshaft removal, refer to Camshaft Removal and Installation . 8.Using a micrometer, measure the thickness of the removed valve tappet. 9.Calculate the thickness of the newly installed valve tappet through the following equation.
A: thickness of newly installed valve tappet
B: thickness of removed valve tappet
C: measured valve clearance
Equation
    Intake valve: A = B + [C - 0.20 mm (0.008 inch)]
    Exhaust valve: A = B + [C - 0.30 mm (0.012 inch)] note The valve tappet ranges 3,000 - 3,690 mm (0.1181 - 0.1453 inch) and has 47 types per 0.015 mm (0.0006 inch). The thickness below a decimal point is stamped on the reverse side of the valve tappet. 10.Install the valve tappet selected through the procedure 9, and put the camshaft in position. For the camshaft installation, refer to Camshaft Removal and Installation .
    11.After installing the timing chain, measure the valve clearance using the procedure 3 to 6. Confirm the clearance is within the standard value.
    caution Completely remove all the old FIPG, which might be remaining among the components. 12.After completely removing the liquid gasket adhering on the timing chain case, cylinder block and cylinder head, degrease them with white gasoline.
    caution The cylinder head cover should be installed within 3 minutes of applying liquid gasket.
13.Apply a 4 mm bead of liquid gasket as illustrated.
Specified sealant:
    THREE BOND 1217G or equivalent
14. Install the cylinder head cover and tighten the tightening bolts using the following procedures.
(1) Temporarily tighten to the following torque in order shown in the illustration.
Tightening torque: 3.0 ± 1.0 N·m (27 ± 8 in-lb)(2) Tighten to the specified torque in order shown in the illustration.
Specified torque: 5.5 ± 0.5 N·m (49 ± 4 in-lb)15.Install the ignition coils.
Jan 23, 2017 | Cars & Trucks
What is the valve clearance for D399 engine
Using feeler gauges, about .032" on intake tappet clearance, .036" on exhaust tappet clearance.
Feb 27, 2016 | Caterpillar D399 Generator Drive Engine
Adjustment clearance valve rocker tappet
Pulsar 135 original tappet clearances
INTAKE VALVE 0.05 mm
EXHAUST Valve 0.10 mm
Get this valve adjustment done by the experienced mechanic with the help of Feeler Gauge
Aug 28, 2013 | 2010 Bajaj Pulsar 135 DTSi
Mazda 6.2 engine valve clearance
tappet clearance for this engine i wouldnt know offhand but 12 inlet and 14 exhaust will suffice without doing any damage and 25th for the plugs
Apr 15, 2012 | Mazda Cars & Trucks
What are the intake and exhaust valve tappet clearance specs. of a honda civic 1999 1.6 liter vtec sohc engine?
Valve clearance Inches Millimeters
Intake 0.006-0.007 0.15 - 0.19
Exhaust 0.007-0.008 0.17 - 0.21
Apr 08, 2011 | Honda Civic Cars & Trucks
What is the valve lash adjustment settings on a craftsman 6.5hp tiller
Hi bbg713,
I hope I can help you out. The valve lash (tappet clearance) on engines of approx this size should be 0.005-0.007 inches (0.13-0.18 mm) for intake valve and 0.007-0.009 inch 0.18-0.23 mm for exhaust valve (cold engine). Adjust tappet clearance by grinding end of valve stem to increase clearance or grind valve seat deeper to decrease clearance. I hope I have helped you a bit. Any more questions are welcome. Regards and good luck. Denis.
Mar 31, 2011 | Craftsman 8.50 Torque Rating Rear Tine...
Procedure of tappet adjustment
make sure engine is warmed up. Put cylinder one at top dead center,remove the valve cover,loosen all adjustment lock nuts,adust intake and exhaust valves on cyl #1 and intake valve on #2 and exhaust valve on #3. now rotate crankshaft 360 degrees clockwise, now adjust intake valves on cyl#3 and cyl #4 and exhaust valves on cyl #2 and cyl #4.now tighten lock nuts and install valve cover. specs are intake valves 25mm clearance and exhaust 28mm clearance, use a feeler gauge,heres a picture to show you where to check clearance.7675a52.gif
Mar 14, 2010 | 1986 Suzuki Samurai
WHAT IS THE TAPPET CLEARANCE FOR NISSAN GA 15 CARBURATED,INTAKE AND EXHAUST?
what is the tappet clearance setting for the ga15 nissan sunny
i need help to know the clearance of intake and the exhaust valve.
Nov 02, 2009 | Nissan Sentra Cars & Trucks
Engine tappet clearances
According to http://freespace.virgin.net/tommy.sandham/databook.htm# Rocker Adjustment, the cold clearance is .008" intake/.018" exhaust in the non-GT 1500cc, and .012" intake/.022 exhaust on the GT. Sweet little car!!!
Mar 01, 2009 | Ford Escort Cars & Trucks
Valve tappet adjustment
well, I can see ur message has been here for quite some time. Most probably you got the answer to ur request.
I just did the valve clearance on the engine of my SJ413 that has the 1000cc engine of an SJ410 :
When cold: 0.13mm Intake and 0.18mm Exhaust
Engine sounded well and worked fine after that.
Enjoy
Mehdi
Nov 18, 2008 | 1986 Suzuki Samurai
Computers & Internet Logo
David Payne
David Payne
