Question about eMachines Computers & Internet
I have a eMachine G640 and randomly my screen turns white and will remain white screen for around 1-30 mins and then it will return back to normal this can happen between 1-8 times a day and I do not see a pattern on when it occurs. If I plug the laptop into a monitor using a HDMI lead i can see my screen on the other screen.
    New Friend:
  • 51 Answers
You need to change the screen. it is bad.....tekgods.com
Posted on Oct 26, 2013
  • 12 Answers
SOURCE: My monitor will remain black when notebook is powered up
Your monitor may be configured for a mode that is not compatible with your display device. Start your PC in Safe mode by holding down the F8 key from a cold boot.  If your display comes up in 640x480 mode, then your problem is your display settings and can be corrected by right-clicking on your desktop, selecting PROPERTIES and then the SETTINGS tab.
If new settings do not work check your SLEEP settings in the control panel to make sure you are not "hibernating".
Failing all these, re-install the drivers for your display adapter from safe mode.
If your monitor did not come up in safe mode (remained black) enter your BIOS (CMOS) settings and ensure that your primary display is set correctly.
After these non-invasive things fail, take it back and get it covered under warranty, you have a hardware problem.
Posted on Oct 15, 2007
tom19511
  • 1601 Answers
SOURCE: colour fluctuation on laptop screen
Are you close to any electrical signal?
For example lamps,cordless telephone, tv,, speakers?
Posted on Nov 23, 2007
patemi
  • 366 Answers
SOURCE: White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Posted on Dec 30, 2008
Murphybanton
  • 2004 Answers
SOURCE: Screen problem HP DV9000
Please perform system restore on your pc. Restore to factory default and remember to backup your documents.
rate this
Posted on Jun 04, 2009
justin217
  • 85 Answers
SOURCE: white screen. what does it mean?
Your LCD might have gone out, call the sony support number for a service request or take it to your local computer repair shop. Hope this helps!
Posted on Jul 12, 2009
My emachine E525 goes white after logon
First try to start pc in safe mode,by normally Pressing F8 key when windows starts up
If you have done then update your graphic drivers just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
-Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If -If this didn't help you then simply get the Intel software partner Reginout to fix all the errors and registry issues which causing blue screen
Jun 18, 2013 | Acer Computers & Internet
Emachine laptop goes white after logon
- First try to start pc in safe mode,by normally Pressing F8 key when windows starts up
- If you able to strt in safe mode then update your graphic drivers just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs and white screen
-If this didn't help you then simply get the Intel software partner Reginout to fix all the errors and registry issues which causing white screen
Jun 18, 2013 | eMachines eM250-1915 Netbook
Hi , I am using hp pavillion dv4 1131tx laptop. My screen always randomly turns black and then shuts down after a few seconds. when i start it back up, i get this message: "The system bios has...
well your CPU centeral processing unit is overheating ..check the fan if its still working.. if its then try to clean the fan take it part and get it clean .
May 06, 2011 | Computers & Internet
The phone turns on but the screen remains black.
remove your battery and SIM card for about an hour. make sure the phone has never been wet.....if you see a red sticker on the battery on below where the batter ysits, in the back of the phone, then the phone has been wet.
after the hour is up, put the phone back together and turn it on and see what happens.....the LCD couldve simply died, as this happens a LOT. you can find a replacement on eBay for pretty cheap, otherwise you'r elooking at a warranty exchange or buying a new phone outright.
Oct 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Sony ericsson k750i-white screen in camera
On the side where yuu can turn your volume up and down for the phone the brightness is just turned up, press the down button to make it return to normal. Try that
Jul 12, 2009 | Sony Ericsson K750i Cellular Phone
Blackberry storm has random resets
i called verizon have the same problem and they said to deinstall an 3rd party apps. i have 3 face book, whether bug, and vlingo. thick around what time it did it what apps did you just get. i thick vlingo is one of them. my brother has it on a curve and said to get i did and just a cupel of days after i notes it.
Apr 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
Laptop screen goes blank at random times.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
Go to www.lcdparts.net for parts detail and installation
Feb 28, 2009 | Dell Computers & Internet
White blank screen
Dec 30, 2008 | Acer Aspire 4315 Notebook
White screen on my phone sony w550i
Hi this is a almost normal anomaly with sony ericssons - they get the "white screen of death" on a regular basis - on my w550 back in the day - exactly the same thing happened - after reflashing a few times it was back to normal - we are sony ericsson experts if you need it done
http://horizonwirelessonline.com
Jan 22, 2008 | Sony Ericsson W550i Cellular Phone
Computers & Internet Logo
87 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
