Question about Denon AVR-5800 Receiver
Denon avr 5800
Speaker cable accidentally touched. Power on but no sound. Replaced fuse several times but every single time is blown instantly as power is turned on.
  • 1 more comment
  • baothanh Sep 02, 2007
    I replaced the 12v ceramic fuse.
  • baothanh Sep 03, 2007
    Hi, this is the picture of Denon AVR-5800 with top cover off.
  • Anonymous May 19, 2009
    Hi I have the same receiver BUT all my lights and status indicators are on but I have no sound in any digital input modes - i plug an ipod into the CD input and I can hear Stereo, Pure Direct and Direct (it is the sweetest ounding amp i have ever heard) but nothing else works. I can pass thru to view OSD - no sound on the digital inputs - plugged DVD player in as well as a CONCAST BOX via Optical Inpiuts that were correctly configured. no sound coming out? is there a master volume muting button? i do not have the original repote as well - using Harmony remote. ideas? is this a fuse? transistors? blown amp, blown dsp? who knows.
    New Friend:
    Problem Solver:
  • 6 Answers
I can help you solve this problem. However you must describe to me which fuse you have replaced. Is it the fuse on the power line or is it a fuse in the speaker line (which I highly doubt). usually this type of amplifier uses two technologies. One is transistors the second is integrated chips. This is in regard to the output stages. I assumed you speaker cables shorted each other while the volume was set at a high level with music playing. Anyway if you are willing I am able to help.
Posted on Sep 01, 2007
  • Tinu Patel Sep 02, 2007
    Now the problem is somewhat clear. I suspect shorted transistors or main capacitors are shorted. This requires some troubleshooting on your part. However if you need me to help you you need to be in new jersey. Or else you can send me pictures of the amp opened with the top cover off. I can the direct you on troubleshooting.
  • Tinu Patel Sep 05, 2007
    OK this is a convential power supply system. If the power does come on and stays on most likely nothing is wrong with the main capacitors which are the two small circles to the left of the big black circular transformer. It is safe to say you have blown transistors. If you are familar with testing diodes then you need to put the DMM in the diode checking mode. Next realize that a transistor BJT are usually two diodes back to back. It may be also possible you have mosfet power in which case the testing is a little different. If you are willing to do this kind of troubleshooting, judging from the picture it seem a lot of work to get to the transistors that are mounted on the heat sinks let alone trace the correct one for the front channel. Your amplifier should have protected itself from the short circuit. Did you short the speaker terminals together at high volume? or did you blow out the speakers at high volume? The reason for my asking is very simple, the short circuit protection circuitry could be at fault where it keeps the output from turning on even though everything is ok. In conclusion the only way I can really help is for me to look at it myself. Even then I cannot guarantee that we will be able to fix it.
Posted on May 19, 2009
SOURCE:
When I power my Denon AVR-3311ci on, it only comes on for a second then shuts off completely. No blinking red light and nothing on the display. I can hear a relay on the power board clicking. Any ideas?...
Greetings
have you checked the speaker cables ?
please do
Usually the Denon system has a problem with power regulators
if u have any knowledge in electronics i can guide u to repair it
if not .. u have to send it to service.
check for fuses if blown
power regulators mostly are damaged
and or power output transistor damaged
Good luck From Audio-adviser.com
Feb 17, 2015 | Denon AVR-3313CI
Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Dec 11, 2007 | Denon AVR-4800 Receiver
Denon 4806
If the channel is blown and you have replaced the fuse your receiver needs a trip to the repair shop.
Aug 24, 2014 | Denon AVR-4800 Receiver
No sound
check speaker conections. disconnect all the speaker wires and use one speaker that you know that works and connect it to each channel one at a time. most surround sound stereos will not go into surround mode unless all the speakers are connected so make sure stereo is in 2 channel mode to start testing. check all fuses sometimes amp fuse is seperate from power circuit and denon uses relays in 99% of thier units.
Dec 23, 2010 | Denon AVR-2802
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
I got the same problem with my Denon AVR-2105/885
Your receiver is going into protection. The first thing to do is disconnect all speakers at the receiver. Unplug the power cord, then let it set for 30 seconds. Plug it back in and power it on. If it stays on, you have either a wire shorting out at the back of the receiver, something that has pierced the speaker wire en-route to the speaker, a wire touching the other at the speaker or a blown speaker.
Speaker wires should only be trimmed about 1/2" bare at the terminal and make sure you twist the braid so it does not fray. Then connect speakers one at a time, testing the receiver power each time until it either shorts and cuts out, or, you have solved the problem. Hope this helps. If you need more help, post a comment and I can help you some more
Jul 09, 2009 | Denon AVR-1604 Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Sound problems
try to introduce your speaker one by one and check every time you enter the speaker check for bad cable(internel short)open cable cover and touching of adjacent cables together.-try to change the position of your speakers.
Jul 12, 2008 | Denon AVR-1706 Receiver
Denon Receiver flashed PROTECTION and stopped working after plastic smell
i just had the same thing happen to me what did you do to fix it?
Dec 28, 2007 | Denon Audio Players & Recorders
Denon AVR-5800 Receiver Logo
967 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
