Question about KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System
When I turn on the dish to locate the Sat. It starts up to a vertical down, then up, and then rotates in one direction and then locks into a position. There isn't any Sat. reception. I can hear the steering motor running. I unplugged the motor the hum stops and rotation is free. I plug it back in, it locks and hums . Question: do I have a motor steering problem, or a program problem. Do you have a solution?
2 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: The drive belt that rotates the dish has slipped
toothed belt may be slipping because dish is stiff to move, but a new belt is the first step. 847-746-0100 support@technicalmarine.com
Posted on Jan 23, 2010
My dish remote # 2 the select button will not work /
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to help. Have you replaced the batteries? If you have not already replaced the batteries, please do so. If after replacing the batteries,no lights light up on the remote, most likely the remote is defective and will need to be replaced. For further assistance, you can reach me at: kimberly.escobar@dish.com or contact us directly at:1-800-333-3474
Kimberly Escobar
Social Media Representative
DISH L.L.C
Jun 16, 2014 | DISH Network Televison & Video
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Lost my Dish network remote for the upstairs tv (LG) - which has NO box. Is there anyway to program my TV remote, so I can access the TV staions - turn on the network basically???????
No,the Dish Network satalite box signals require it own remote for it INFER RED INPUT and INFER RED OUTPUT signals.Call Dish Network customer service ask for a another original Dish Network remote.U pay $5 or $6 dollars a month for the satalite box as rental.They should wave the fee or charge u very little for a another remote.
Sep 05, 2011 | Universal Remote Control Dish Network...
Pressed the System wizard button on remote the Sat button lit up for a minute or so then the remote stopped working ! Changed batteries still not working ! reset the box still not working What do I do ??
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like your remote may need to be readdressed to your DISH receiver. I will list here for you the instructions for addressing your remote to your receiver box. If you are using the TV2 remote make sure you take it to the TV1 location to perform the trouble shooting steps. If you are using TV1 remote stay at the receiver box location. I hope you find these instructions useful and if you have any further questions or concerns feel free to post back here or email me directly at Cheri.Torres@Dishnetwork.com.
Instructions for addressing remote to DISH receiver
  1. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver box or by pressing the power button once then the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the white square.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Mar 07, 2011 | DISH Network IR Remote Control
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
I have reprogrammed my dish remote to my tv but when i activate the sat button nothing happnes. what do i need to do?
Press menu -menu on the receiver. You should be able to see the remote address for the receiver. It will typically be set to 1 if it reset somehow but whatever the case make note of this number. Take the remote and hold the SAT button until all lights across the top illuminate. Now key in the two digit address- single digit numbers are preceded by a 0. Now press the pound sign in the lower right of the remote and observe that the SAT button flashes thrice. Now press the record button a few time to ensure it is locked. Now try exiting the menu screen with the remote.
If this does not work check the antenna on the back of the receiver and put it in the full vertical position and try again. If this fails you may need a new remote.
Thanks for using for using Fix Ya.
Ihope this resolves your issue.
Dec 20, 2009 | DISH Network 721 DVR Remote Control
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Sep 05, 2009 | DISH Network DVR-625 DTV Receiver /...
Dish Network - Dish 500 Satellite 110 is not being recognized
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Oct 18, 2007 | RCA DISH Network(r) 311 Satellite System
Vertical lines in picture
If your satellite is in the component jack and does not have the lines, you have a bad doubler or 2HD board. These boards are located in the metal container on the left side of the tv (left as in when you are looking at the back of the tv).
Mar 31, 2007 | Mitsubishi WS-65809 65" Rear Projection...
KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System Logo
Top KVH Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a KVH Boating Expert? Answer questions, earn points and help others
