Question about Frigidaire FAH085N1T Air Conditioner
Unit not draining properly wanting to know if I can drill small hole in bottom of unit and which side so it will drain its 110 window unit
2 Suggested Answers
wise_jf
  • 66 Answers
SOURCE: there is no drain hole for water to drip outside.
These are designed to retain some water in the pan. This is for the slinger fan to throw water through the condensing coil. This helps the refrigerant cool and is important to the efficiency of the unit. I would certainly not recommend drilling a hole in the bottom. The hole may cause the water to roll somewhere where damage could occur. Try instead tipping the unit Backwards before bringing it in the house.
Posted on Jul 14, 2010
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Aug 18, 2017 | Heating & Cooling
I have water in my 2001 Dodge ram head light cover drivers side, how do I get it off and drain the water from it???
Just a suggestion if you don't want to take your headlight off to try and drain the water, take a small drill bit and drill two holes in your headlight one on the bottom on the side where the water lies the best and one on the top so it can let it run out good, not no big drill bit but one that will let it drain good, won't hurt your headlight.
Dec 24, 2011 | Dodge Ram 1500 Cars & Trucks
My '99 wagon spare tire boot gets an inch of water in it after rains. The compartment holding the tire jack also fils up, and the small floor area behind the drivers side rear wheel well also getrs...
What is the make of your wagon? Regardless you shouldn't be drilling holes anywhere. Check your rear window seal, tailgate or lift gate seals.
Apr 10, 2017 | 1999 Ford Escort
When there heavy rainfall , water goes itno the passenger side door i have to move the rubber on bottom of door to let water out, why is this hapening ?
There are small drain holes along the bottom of the door, and it sounds like yours are clogged. Inspect the window seal along the rear edge and along the bottom window seal where the glass meets the door.
Another option would be to drill small, additional holes along the bottom of the door. If you do, make sure you locate them on the outside of the rubber seal. Otherwise, the water will drain inside the car. Hope this helps.
Aug 17, 2011 | 2005 Cadillac CTS
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
I have a 6000 btu window unit. I was wanting to know how the unit drains the water. where does the water come out of the unit at? I could not find a drain hole.
No drain holes on most units that size
The water gets from the front evaporator thru
a small hole you can not see
Then it finds it's way to the outside or back on the
bottom metal pan
It is evaporated by the condensor fan
It may drain out over the rear pan lip, if
it gets alot, but no drain hole is necessary
You can angle the unit down at the outside or
rear & you can drill a small hole, but it uses the water
to cool the condenser
Aug 04, 2011 | Haier HWR08XC7 Air Conditioner
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls...
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Aug 15, 2010 | Frigidaire FAC126P1 wall/window Air...
Water leaking from Maytag M6T12F2A is this expensive to repair
The drain hole is likely clogged with lent and trash. Make sure it is level or leaning dow a bit on the back side. I had to drill five holes in the bottom rear of my old window unit to stop water draining down the insdie wall. Make sure you dont drill into a usefull component of the AC or kiss it goodbye.
Aug 21, 2009 | Maytag M6Q10F2A Air Conditioner
AC accumulating water, not draining properly????
For some reason, newer AC window units no longer are made with a fluid drain. I think the intent is for the unit to be mounted at a sufficient angle (it MUST be angled back so the fluid drains toward the back of the unit) that the rear (outside) fan kicks the water over the condenser coil and gets rid of it that way, it also increases cooling ability slightly in this manner by misting the condenser coil. I would suggest increasing the angle of the back tilt by adding a 2x4 maybe under the unit to allow it to tilt? Alternately, you can drill a hole in the rear corner of the unit to drain fluid, but this is not recommended for several reasons...
1) It will usually cause rust to start at the drill hole.
2) you could accidentally puncture the coil system while drilling
3) the manufacturer did not make a hole, because one was not intended.
Jun 17, 2009 | Heating & Cooling
Water dosent drain
well lets work with it becouse that the one you have..first let me tell you dont make that hole becouse the water that remaing in the tray is use to cool down the condenser and beleve me its a good idea..its not supouse to condese more water thant he can evaporate..but try to screw a littel bit more the two screw in the back of the cabinet to down the cabinet 10 degrees more to see if that help you...good luck
Aug 03, 2006 | Haier HWF05XC5 Air Conditioner
Frigidaire FAH085N1T Air Conditioner Logo
23 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
