Question about Car Audio & Video
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the boat aren't giving me any audio. I have check that the balance and fade are set to zero. Please help.
    Sergeant:
  • 288 Answers
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Posted on Sep 11, 2013
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
XMD3 I bought a second hand boat with this radio , not working , do you have an installation schema ?Thanks
hello there ,firstly at the rear of the radio you will see two plastic blocks top block is your power in )secondly bottom block is your( audio ) sound these wires are colour coded for front and rear speakers ,your dc power which cannot be over 13.8v black and red wire on top block you have a socket to the right this will be for the antenna ,also check the fuse line before switching on hope this helps you
goodluck
Mar 25, 2011 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
How do you adjust the front/rear balance?
push the A-M button on the face until you see balance then use the left and right buttons you would normally use to rewind or FF....
Jul 02, 2010 | Clarion XMD3
CD doesn't eject CLARION XMD3 marine radio
Disconnect the fuse of radio and reconnect it again.
That should force him to eject the CD
Oct 27, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Clarion XMD3 Condensate Problem
the only way to remove moisture is to get it looked at by a local repair shop .Or remove radio yourself ..let it dry for a few days and see if it helped .Water in LCD may not dry completely and may rust LCD with in time
Aug 05, 2009 | Clarion XMD3
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
CLARION MARINE SPEAKERS CONE DETERIORATED
of course, the only problem is finding someone to do it, and is the speaker really that nice and worth the money
Mar 21, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Oct 19, 2007 | Clarion XMD3
Clarion MXD3
only front speakers are working. How to get rear on also.
Jun 07, 2007 | Clarion XMD3
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
