Question about Kenmore Refrigerators
Cubic size, Kenmore coldspot refrigeratot mod. 60982990
  • 36 Answers
SOURCE: What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Posted on Dec 12, 2008
  • 190 Answers
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Posted on Apr 08, 2009
SOURCE: cubic feet size of Kenmore refrigerator
Try this site: http://www.kouba-cavallo.com/refmods.htm
Posted on Nov 12, 2009
  • 2696 Answers
SOURCE: kenmore coldspot mod:78202891 defrost not working
if you have water leaking into the fridge it sounds like it's defrosting but the drain is blocked and the water has nowhere else to go but into the fridge.when you send the model number send the first three numbers too i think it's 106.,if you have a defrost problem the back inside wall of the freezer would have like snow covering it,look where the light is in the fridge section,you'll see a hole,stick a stright blade screw driver in it and turn slowly,this is the timer,leave the freezer door open while you do this,when you turn it you'll hear a click and the fan will stop blowing,you just put it into defrost mode,the heater will come on and start melting the ice,while it's in defrost remove everything out of the freezer,remove the freezer floor and back inside wall,with a hair dryer melt all the ice you see and then you'll see the drain hole under the coil,you have to clear the drain,i use a steemer to blow through the line,then pour hot water into the hole,if it drains down i know the drain is clear,if you don't have a steemer you need something that will blow or push water through the line like a turkey baster or some guys say they use a shop vac set on blow but whatever works to free the drain,keep hitting the hole with the hair dryer and stick a screw driver into the hole,the blade will heat up and slide into the drain to melt the ice,also you can heat up the ceiling in the fridge section in the back,middle of the ceiling,the drain is in there so heating that up will help,when you think the drain is clear pour hot water into the drain,if it drains through you're done,if not keep hitting it until it's clear.when you clear the drain you can buy a heater probe that you rap one end around the heater and stick the other end into the drain hole,when the heater comes on the metal warms up keeping the drain from freezing or if you have a piece of house wire you can make a probe out of the ground wire,cut it around 6 inches,bend one end so you can slide it onto the heater,stick it into the drain until you feel it hit the bottom,cut around a half inch off it so it won't block anything in the bottom of the drain and then attach it onto the heater or if it's a glass heater attach it to the metal cover that's in front of the heater.if you don't want to put anything in the drain that's ok too.good luck with your fridge and i hope this helps you out.
Posted on Oct 28, 2011
richroth
  • 9472 Answers
SOURCE: What is the cubic feet of kenmore coldspot refrigeratior model #106.9530482
This is a 20 cubic ft. side by side refrigerator.
Posted on Oct 17, 2012
Kenmore coldspot refrigerator 106.9555711, serial SF 1317588. What is the cubic feet?
The third digit after the dot usually provides the refrigerator's capacity. This suggests that the 106.9555711 is a 25 cu. ft. refrigerator. If this is an apartment-sized fridge, then it may be a 15 cu. ft unit instead.
I hope this helps.
Aug 20, 2017 | Kenmore Refrigerators
How many cubic feet is Kenmore Coldspot Refrigerator Model 10674254400 Serial ER3139075
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
Apr 15, 2017 | Kenmore Refrigerators
How many cubic feet in a Kenmore Coldspot model # 106.70182000
Call kenmore or appliance store they can tell you or call Sears store
Apr 20, 2015 | Kenmore Refrigerators
I would like to know how big my Kenmore Coldspot Refrigerator is? It is model 106.51554104, Type 25 SSA. Made in 2003
Here is a tip that I wrote that tells you how to figure out how big yourrefrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Oct 13, 2010 | Microwave Ovens
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Refrigerators Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
