Question about Home Security
Dmmultiview can't connect to server
Ip address is correct. ports 4550 and 5550 are open. was working. just replaced the pc housing the geovision software
jeesusfreek
  • 18 Answers
SOURCE: PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Posted on Feb 01, 2008
SOURCE: port forwading
http://portforward.com/
this site may be of some assistance
Posted on Jun 19, 2008
jsbasrao
  • 54 Answers
SOURCE: TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Posted on Mar 20, 2009
jhoeldorz
  • 169 Answers
SOURCE: No internet on PC when cables going through router
Hello there,
You have to start from the beginning and my solution would be:
1) Remove any connections(also don't forget to turn of wifi on your laptop) to router and except the power cord. With the unit powered ON locate the reset pinhole on the back of router.
2) Press and hold reset button for at least 15 secs. then release, wait for 20-30 secs. before the router can completely rebooted.
3) Configure your Computer IP address to “Obtain an IP address automatically” .
4) Connect internet cable to router on port labeled "WAN". Connect PC to any LAN ports available.
5) Now lets configure wireless router. Open any browser you have (IE, Firefox, Chrome, Safari, etc.). On the address bar type: "192.168.1.1" (without quotes). Default username: admin ; default password: admin click "OK".
6) Go through "SETUP WIZARD" until you reach the "Setup WAN Interface" page. On "WAN Access Type:" select "DHCP" then click next.
7) You may configure your "Basic Wireless Settings" to Public or Private until finished configuring.
8) On "Operation Mode" be sure you operate on "Gateway" mode.
That's it! Hope this helps.
Don't forget to vote.
Posted on Mar 12, 2010
SOURCE: Checking virtual IP servers... [VIP Raw]
elisei_eli2008
Posted on Mar 15, 2010
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router...
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Tip
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when asked this will set up your wireless laptop with the correct printer port based on the Wireless Node Name it will also use the printers inbuilt MAC address. This is standard install and will work for all your Wireless PC's however if you have a Wired (ethernet) PC connected to your Router this process will not work a wireless port will not work with a wired computer.
Follow my 3 steps below to set up standard IP ports for Wired PC's also connected to your Router.
STEP 1: Find your MAC address for the wireless printer (all types of Network Cards will have one so this is no different) this will either be found under the LCD control panel or may even be printer on the bottom of the printer or Print server if it is seperate set this MAC address with an IP address as a reservation in your admin panel of your router 192.168.0.10 in this example.
You can normally enter your Router this using 192.168.0.1 typed in your browser (not the search engine) as all routers are different check here for your make and model http://www.routerpasswords.com if you can't find the MAC address try using ipconfig /all from them command prompt it will be the physical address aka the MAC address
STEP 2:
Install the Printer as a USB printer port by connecting the USB cable to the PC you want the wired printer driver installed on when finished go to the printer driver properties for the driver you have just added, click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install and connect your Ethernet cable from you computers NIC to a spare RJ45 socket on the Router.
STEP 3: To check that the Printer has the correct IP address then test using the tracert OR ping command for the IP address that you have reserved on your router, this is a necessary step otherwise when the lease expires it may take another IP address and your Printer driver will not work unless your printer has the reserved address, it will throw a printer error.
c:ping 192.168.0.10
(this example shows a Standard TCP/IP Port for a Brother DCP-340CW)
Also check in your routers admin panel to see if the Wireless Printer is set up with the correct IP and MAC address, if you still can't find it eliminate your known MAC addresses from all your network cards the one left will be your Printer Server NIC in your Wireless Printer.
If you have setup the incorrect IP and or MAC address you will get this window when you try to add the TCP/IP port
That's it try a test print and you will see it burst into life.... Happy Printing
on Dec 02, 2009 | Office Equipment & Supplies
Cant sign into yahoo messenger. Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw]...
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [PASSED]
[VIP Raw] PASSED *** 98.136.48.85 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0001' ***
Aug 10, 2010 | Yahoo Messenger
Hello I am getting to theGV-800 Geovision pag...
I am not sure what trouble shooting you have already done but a few of the basics are.
1.you cannot connect to your own Geo Web server within your own network, you will have to do it from outside. you can connect within if you use your internal ip address.
2.make sure your router is open for incoming and outgoing connections on ports 80, 4550, 5550.
3.Try connecting without the router if you have one.
4. Geovision works with internet explorer only, not Firefox,, try the DMmultview program that came on your software disk.
try those suggestions first
Regards
Marvin
May 19, 2010 | Geovision GV-800-16 Video Capture
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
Laptop suddenly loses connectity on port but IP phone stays connected with no problem. Will not recover until a reboot of the 5505. I move the laptop to the phone port and the laptop reconnect instantly....
Check your DHCP server settings. Do you have your voice and data riding on the same subnet? I would start at the DHCP server and work my way back to what the configuration of the phones IP, GW and subnet mask are and verify that it is pulling from the correct pool of addresses. It is always best to segment network traffic especially voice and data but if it is pulling from the phone reverify the settings on each device and check your DHCP pool, it could be out of addresses in the IP range, or configuration settings are not set correctly. Hope it helps you out!
Cheers!
J the Guru
Aug 12, 2017 | Cisco ASA 5500 Firewall
Nat help
Hi jman92592,
Here are some options with that router. Some online games and videoconferencing applications are incompatible with NAT. The WGR614 router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default in the PORTS Menu. If one local PC acts as a game or videoconferencing host, enter its IP address as the default
To set up an additional computer to play games like Half Life, KALI or Quake III:
1.Click the button of an unused port in the table.
2.Select the game again from the Service Name list.
3.Change the beginning port number in the Start Port box. For these games, use the supplied number in the default listing and add +1 for each additional computer. For example, if you've already configured one computer to play Hexen II (using port 26900), the second computer's port number would be 26901, and the third computer would be 26902.
4.Type the same port number in the End Port box that you typed in the Start Port box.
5.Type the IP address of the additional computer in the Server IP Address box.
6.Click Apply
The WAN Setup options let you configure a DMZ server, change the MTU size and enable the router to respond to a Ping on the WAN port.
Connect Automatically, as Required
  • Normally, this option should be Enabled, so that an Internet connection will be made automatically, whenever Internet-bound traffic is detected. In locations where Internet access is billed by the minute, if this causes high connection costs, you can disable this setting.
  • If disabled, you must connect manually, using the sub-screen accessed from the Router Status menu "Show WAN Status" screen.
•Disable SPI Firewall
  • Normally, this option should be Enabled, so that your local network will be protected by the Stateful Packet Inspection (SPI) firewall included in the WGR614. However, certain communications functions like VPN may require turning off the SPI feature.
Setting Up a Default DMZ Server
  • The default DMZ server feature is helpful when using some online games and videoconferencing applications that are incompatible with NAT. The router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default DMZ server.
Note: DMZ servers pose a security risk. A computer designated as the default DMZ server loses much of the protection of the firewall, and is exposed to exploits from the Internet. If compromised, the DMZ server can be used to attack your network.
The WAN Setup menu, shown below lets you configure a Default DMZ Server.
  • To assign a computer or server to be a Default DMZ server, follow these steps:
1.Click WAN Setup link on the Advanced section of the main menu.
2.Type the IP address for that server. To remove the default DMZ server, replace the IP address numbers with all zeros.
3.Click Apply.
Good Luck and don't forget to leave a rating.
Thanks Mark
Apr 23, 2009 | NetGear WGR614 Wireless Router
Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Feb 18, 2009 | Dell PowerEdge 2600 Server
Home Security Logo
405 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
