Question about Kitchen Appliances - Others
BRITA MODEL NUMBER RK2001W/OB03: Hot and cold
BRITA MODEL NUMBER RK2001W/OB03: Hot and cold water indicator light remain in off position. How can I fix it ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Change LED Diode .
Posted on Nov 02, 2013
Water isn't draining and display light not working?
what is the model number to your dishwasher? Geraldine
Oct 01, 2013 | Electrolux Dishwashers
I have a Grohe 32362 AVO bath faucet that began to show signs of slow water flow (both hot and cold). I turned the water supply valves off and then full "on" and then water flow ceased entirely? The...
hi, the fault is probably from a tempering valve, on the inlets (hot and cold feeds to the tempering valve) there are little filters that block up easily undo the connections to the tempering valve remove the filters and clean them
Jun 12, 2010 | Grohe Chiara Neu Lavatory Centerset ...
When i turn on the cold water to adjust the temperature of water - the hot water turns completly off. I cannot turn on the cold water at all. It is either all hot water or all cold.
It might be a question of inadequate flow. All tankless water heaters have a minimum flow rate that must be met, typically .5-.9 gpm, before the heater will operate. In the summer time the incoming ground water temperature is higher, causing you to mix more cold water and less hot water to get a lukewarm temperature. This can reduce your flow rate near or below the minimum flow rate.
Here's a test for you, try running running a sink while taking your next shower. If the hot water remains mostly constant throughout, then your problem is with flow at the showerhead. The flow at a shower head can be reduced by buildup of scale and sediment. Also all showerheads have a flow restrictor that limits flow to 2.5gpm (some even less). Removing the restrictor will increase the showerhead flow rate as well.
Also look for any error code displayed on the digital read out of the heater. Some heaters will flash on their burner indicate light as well.
Aug 17, 2009 | Water Heaters
Need temp control for water cooler has BOTH HOT/COLD
Company called Ranco makes replacement contols. Contact your local Appliance Parts Dealer.
Apr 22, 2009 | Refrigerators
Indicator light for Brita filter not working
I see this alot when I do installs...contact the Brita tech support
1-800-24-BRITA (US)
Jan 30, 2009 | Plumbing
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
When on hot water selection no hot water comes out
This an indication that the hot water solenoid in the water inlet valve has failed. If you replace the valve, I bet your problems go away. The following link provides you with step-by-step instructions on how to replace one:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Please post back with your COMPLETE model number (located along the wash tub opening under the washer lid) if you require parts assistance. I can help you locate them online, or provide you with the a part number. I hope this helps you.
Jul 02, 2008 | Kenmore 22422 Top Load Washer
Kitchen Appliances - Others Logo
267 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
