Question about Icom Ic-m34 Vhf Waterproof Marine Two-way Radio
Ic m34 always open squelch - Icom Ic-m34 Vhf Waterproof Marine Two-way Radio
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Put your squelch at 3 or 5
Posted on Jul 11, 2016
Why won't my ic-m34 doesn't receive - Icom Ic-m34 Vhf Waterproof Marine Two-way Radio
If it can receive some signals that are close to you, then the RF front end protection diodes are likely shorted. This would require someone with expertise in surface mount components to repair. Take it to a dealer and have them look at it.
Sep 07, 2017 | Icom Radio Communications
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
Check Rx sensitivity if low then change filter
May 11, 2014 | Icom Ic-m34 Vhf Waterproof Marine Two-way...
Diagrama ic m34
Maybe Kia can supply what you need.
Apr 20, 2014 | 2001 Kia Rio
Ubc330crs squelch not working
Check in the menu? for a squelch on / off function.
Feb 04, 2014 | Radio Communications
Dear sir I HAVE VHF MARINE TRANSCEIVER IC-M34 for 2 years ago, suddenly, I can't receive any signal ( transmitting without receiveing ) but if I set the squelch to 0 level I can reveive signals and...
This is a front end issue that has to be remedied by a radio tech or the factory. The front end is the receiver and it takes special tools and equipment to test and calibrate it correctly,, The only thing you can do is check the ICOM page to see where it can be serviced.
Nov 27, 2017 | ICOM Informatique Floating Hand Held Vhf...
Icom IC-M34 transmit correct but do not receive if sql is above 0
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Mar 13, 2011 | ICOM Informatique Floating Hand Held Vhf...
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
Sep 11, 2007 | Radio Shack Pro-2096 Base Scanner
Icom Ic-m34 Vhf Waterproof Marine Two-way Radio Logo
Top Icom Radio Communications Experts
Steve
johncassells
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
