Question about Zanussi 23 in. ZDT6255 Built-In Dishwasher
Resetting Zanussi Anti Flood Device without removing built-in dishwasher
I think I know why the anti-flood device has been activated - my kitchen sink overflowed and water flowed across and behind the built in dishwasher. I don't want to pull the dishwasher out to tip because it looks like its been screwed in, and there are no obvious hand holds to pull it out. If I'm right about why the anti flood device has activated is there any other way (apart from pulling out and tipping the dishwasher) to reset the antiflood device? Do I have to wait for it to dry off? Best, Jamie
  • Jamie Ashmore Aug 01, 2013
    solved it, remove inspection panel at bottom and soak up excess water with sponge cloth.
4 Suggested Answers
SOURCE: Dishwasher was tipped and won't run
I have the same problem if you take off the tray below the front door and set a small blow heater in there it will dry the out the anti flood switch. It usally takes about 25 mins for the machine to start working again.
Posted on Jul 20, 2007
SOURCE: anti flood device needing reset
pull the dishwasher out and tilt it forward to reset..worked on my electrolux.
Posted on Oct 31, 2008
SOURCE: newish Zanussi ZDF 511 dishwasher fills the antiflood device
If you cannot find a leak then check that if you are using the 4 or 5 in one tablets that you are not using rinse aid seperately as this is also in the tablets and salt.Too much rinse aid can cause the dish washer to froth up and this can overflow down the underside of the door causing the problem you have.
Hope this helped.
Posted on May 13, 2010
Zanussi dishwasher anti flood device
There is a water level pressure switch that is your issue. Replace that or if youre lucky, clean the hose/pipe connected to the pressure switch and it could work again.
Feb 10, 2016 | Zanussi Dishwashers
What is code.30
Zanussi ZDF 511 User Manual
anti flood device is activated,call for service
Mar 31, 2015 | Electrolux Genuine ZANUSSI ZDF511...
Dishawasher floods
Two possible reasons come to my mind. First, and simplest, I've seen Dishwasher installations that did not use a air gap in the Dishwasher drain (usually a dome device mounted on the back of the kitchen sink or sometimes mounted in the wall just above the sink in older homes).When an air gap is not used, it is imperative that a high loop is formed in the dishwasher drain line, and tied up in that position (usually under the kitchen sink,as high as possible- the underside of the sink faucet usually works, or a screw into the bracing under the counter top to wrap a soft wire looped around the drain hose to hold it there permanently). If you do not use a air gap, or have a high loop in the dishwasher drain hose, then likely you are getting a back flow of dirty water into your dishwasher from the drain plumbing to which the dishwasher is connected (likely the garbage disposer or the tail from the sink basin.) So every time you either run the disposer (if you have one), or drain the sink basin, some of that contaminated, dirty water may be siphoning back into the dishwasher There are some exceptions, as some dishwashers including some whirlpool models, have a anti siphon ball device built into the drain pump housing.( You should also check your local plumbing code. They may require an air gap in your dishwasher drain line regardless of anything else.) Secondly,the water inlet valve may be sticking open, or not completely seating closed after the fill cycle. This could be indicated by a very gradual accumulation of clean, clear water in the bottom of the tub, to the point of completely filling the bottom of the tub to the point of overflow at the dam at the front bottom of the tub. The speed of overflow will be determined by how poorly the diaphragm inside the valve is seating. If you suspect this may be the problem, pull the rubber hose off the OUTLET end of the valve, with the machine in the OFF position or better yet UNPLUGGED (water and electricity do not mix, and can KILL you) ,and see that there is not a continuous flow or trickle of water. If there is any flow of water, in this scenario, then you have a bad inlet water valve, and the valve should be replaced rather than attempting to repair. Be sure to reconnect the rubber hose to the inlet valve before plugging the machine back in and attempting to run the machine, or you will have a high pressure flood, and likely electrical shorting under the machine which could likely ruin the machine.
Dec 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
Anti-flood device activated
Check your debris trap usually found at the bottom of dish washer and clean. May need to reset or unplug to reset devise. See what happens after cleaning, good luck, best regards.
Jan 30, 2011 | Zanussi 23 in. ZDT6255 Built-In Dishwasher
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
Nautilus diswasher is sending water out through the "overflow"? next to the sink, flooding the kitchen.
You must have a clog in the drain line. If it is ran to your garbage disposal then that is the first place to check.
Sep 17, 2010 | GE Nautilus 24" Built-in Dishwasher
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
The dishwasher wont turn off. It does a wash cycle but keeps running...help
you have a leak and it is activating anti flood device this switches on the drain pump to stop it flooding your kitchen if the pump keeps running even with the door open thats what it will be,will need inspection by service to trace leak.
Feb 11, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Zanussi 23 in. ZDT6255 Built-In Dishwasher Logo
101 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
