Question about Sewing Machines
Need threading diagram for Rimoldi 529 serger
  • Sewing Machines Master
  • 7,365 Answers
Zenqi
  • 208 Answers
SOURCE: I need a threading diagram for a Viking Huskylock 560ED serger
Call Husqvarna Viking at 440-808-6550 and they will email you a PDF of the manual.
Posted on Oct 01, 2009
SOURCE: have singer 2 needle serger diagram to small to read it
problem solved inlaged diagram,thks ****
Posted on Jan 14, 2010
SOURCE: i have a rimoldi 529 industrial overlocker and
have you managed to fix it yet?
Posted on Feb 07, 2010
  • 1116 Answers
SOURCE: good diagram showing how to thread a 4 thread Juki
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Set the tensions to zero.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Posted on Mar 02, 2010
  • 4 Answers
SOURCE: I need a diagram for threading a 4 thread serger
The inside diagram is for the loopers. For the needle threads, just follow the color coded dots.
Posted on Dec 03, 2010
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
Threading diagram for rimoldi 3 thread serger model 627
Rimoldi Serger Manual PDF And Ebook Files - DocsFiles
docsfiles.com/pdf_rimoldi_serger_manual.html
Rimoldi Serger Manual PDF Files, Manual For Rimoldi Serger honda nx 250 service ... Manual FREE Parts Crochet - Loopers RIMOLDI 8 8 Kl 327 , 527 , 627 , F27 ...Rimoldi Serger Manual Rimoldi B.27.77 Industrial Serger, 3-Thread, Nov 26, ...
rimoldi 329 threading diagram Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your rimoldi 329 threading diagram question. ... Rimoldi orion 627... rimoldi overlocker how to thread Which Model Rimoldi? ... Level 3 Expert.
rimoldi pdf - P(1) - Docs-Engine.com
Feb 05, 2016 | Sewing Machines
Tension off on serger
Is it the needle threads or the looper threads? The threading diagram is critical to follow, and make sure the tension discs are not stuck.
Dec 12, 2013 | Singer Tiny Serger TS380
Rimoldi 329 threading diagram
try youtube for a video or
a1sewingmachines.com or sewvacdoctor.com and ask them if they know where you can get a threading diagram
also check with sewusa.com and ask them
Jul 12, 2013 | Sewing Machines
Need instructions on threading 4-434 overlock serger
Open up the front cover. There should be a diagram right there, and you want to thread your serger step-by-step per the color-coded diagram so that the needle is in time with the movement of the loopers. If you randomly go about threading it instead of in sequence, the threads will collide and you will create a jam. The usual threading order: Upper Looper, Lower Looper, Left Needle, then Right Needle. Do you have long serger tweezers? Do you have a Looper Threader? If not, these are great tools to assist you as the Lower Looper is threaded right to left- an eye all the way to the far left, so it helps to have the tweezers and Looper Threader to maneuver in this very tight area. Many new serger users don't realize that other eye is "hiding" and miss threading it! Hopefully, you have a manual with additional pictures to help guide you. If you need a manual, try allsewingparts.com and perhaps they have one specific to your serger. Note: When you insert your needles (make sure they are #11 and #14 specific for your particular machine), the left needle will be the same size as right needle, but will APPEAR higher once both are pushed up into each of their respective needle shafts. Note: Hold onto needles or put a piece of fabric under the area when changing them/replacing them because they can easily fall out causing damage to your machine. Hope this helps. Jimmy
Mar 31, 2012 | Sewing Machines
Trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Feb 21, 2010 | Husqvarna Sewing Machines
Sewing Machines Logo
371 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
