Question about Home
Microset SR200 FET blown - Home
Lamar vibe286 car audio amplifier has a blown compacitor
if a cap has blown then the mos-fet's has probably gone down and to be honest there will be a lot of other possibility, how did it happen?
Apr 11, 2012 | Lanzar VIBE286 Car Audio Amplifier
My Sony Handycam DCR-SR200 Camcorder has no display
The flexy cable between lcd and main pcb is faulty replace it
Aug 08, 2011 | Sony Handycam DCR-SR200 Camcorder
I have a problem with my inverter in that when i load,it cutts off, and at that moment it is only one lighting point that is on,it tells me that their overload and fuse blown,what do i do?
I have an Aims 2500 W inverter that was damaged from an accidental connection of voltage from the grid. i replace all of the IRF260n FET transistors but it is still shutting down as soon as it is turned on.Can some one tell me if those FET must have a drive at the gate. Before it will work
Feb 17, 2011 | Inverter Aims Pure Sine Wave Power...
Guide
Click Sony Support to download guide book for DCR-SR200
Jun 24, 2010 | Sony Handycam DCR-SR200 Camcorder
Map light fuse on 2008 f 350????
The interior map lamps are powered buy the battery saver relay ( non serviceable relay ) Which is powered by Fuse #25 ( cab fuse panel ).
This is for the engine compartment and illuminated vanity lamps, as well as the map lights.
The FET ( Field-Effect Transistor ) shows the fuse #9 also on it. ( marked interior lighting ), which power the interior lamps ( door / switch ).
Could be a few things if both those fuses are OK.
1. The map / interior lamp combos are usually dual element bulbs, which means if the interior lamps ( door or dimer switch on headlamp panel ) are OK, it could still be a burn out bulb.
2. The FET is having an issue from a dead short ( blown bulb or dead short to ground ). Until the short is correct, the FET will not turn back on.
Start with checking Fuse #9 ( marked as Fuse #8 in the diagram, but that shows headlamp ), which is to the interior lamps, and drives 1 side of the FET.
Jan 07, 2010 | 2004 Ford F150
My Hifonics BX1500d is still going in protection mode... can that be fixed? greets Gerben
sorry, i am in the US. I couldnt begin to tell you where to get your amplifier repaired.
Try contacting HiFonics at www.maxxsonics.com
There are 3 possible conditions a HiFonics amplifier will go into protection -
Ground Loop - Blown or damaged speaker causing damaged Output FET.
Power Supply Failure - Blown Capacitors, Damaged FETs, Faulty Relays.
Thermal Shutdown - Excess Heat.
Mono channel amplifiers are the simplest to work on - and I would Estimate a repair cost of $75USD if it is a simple FET replacement.
Look at one hour of labor plus parts.
Hope this helped.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 28, 2009 | Hifonics BX1500D Car Audio Amplifier
GW712 - error 49
I have successfully used a D1NA60 FET from an earlier version (phase 5) controller to replce the D2NC60. It is a lower rated component but it works. It was necessary to replace the cold solenoid valve (had gone low in resistance to 15 ohms) and the on-board wired fuse as well but all works OK.
A higher rated FET which could be substituted is ST D5NM60.
Sep 12, 2008 | Washing Machines
SONY DCR-SR200
DCR-SR200 is complicated camera and pls contact nearest Sony service shop for proper repair.
Jul 15, 2008 | Sony Handycam DCR-SR200 Camcorder
Home Logo
145 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
