Question about Zanussi 23 in. ZDT6255 Built-In Dishwasher
Anti flood device - Zanussi 23 in. ZDT6255 Built-In Dishwasher
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Anti flooding on aeg 64840
Problem was answered earlier. Please check the water level sensor, check the line , remove and reset. Also check for blocks in the INLET and DRAIN filters.
Jan 20, 2013 | AEG Washing Machines
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
My whirlpool gold dishwasher gu2475xtvy does not turn on. i checked the power and thats fine please help Bob
Note that washers have an anti flood device that once triggered shuts off the inlet water and turns the pump out motor on only. This anti flood device detects any water on the base of the washer due to leaks or in some cases a blocked pipes. The device is made up of a small polystireen plate and micro switch.
Make sure that water is not on the base of the washer and dry and check for any leaks / spills.
Anti flood device has activated on my zanussi ZDF231,also there is quite aloud whirring sound ,like a motor struggling to work
The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water.
Jan 18, 2010 | Dishwashers
Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Dec 17, 2009 | Dishwashers
Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Jan 17, 2009 | Dishwashers
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Zanussi 23 in. ZDT6255 Built-In Dishwasher Logo
22 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
