Question about Raleigh Cycling
I have a Raleigh 21 speed bicycle. I have Shimano shifters. I cannot shift to the big gear on the front of the bike.
  • Raleigh Master
  • 986 Answers
I also would suggest taking to a shop, or if available a bike co-op where they can help you adjust it. If you really want to try it, follow the instructions in the link below from start to finish. YouTube videos are not nearly as good as written instructions from a reliable site, like parktool.com. Front Derailleur Adjustment
Posted on Nov 21, 2016
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Google "adjusting front derailleur" or take it to a shop until you have more experience. There are many good books on this subject because it takes practice to do it correctly. Good luck!
SOURCE: how to adjust the gears of a raleigh bike 15 speed
You will find an entry on this page ( http://sheldonbrown.com/gearing/index.html ) to allow you to learn how to adjust your FD and RD cables, and so forth ( http://sheldonbrown.com/derailer_adj.html ).
Bookmark Sheldon Brown's pages, as well as the video listings at BicycleTutor.com. If you're going to do this kind of thing yourself, but haven't done it before, you'll want to go back to those two sites again and again.
Posted on Sep 07, 2009
  • 61 Answers
SOURCE: shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Posted on Nov 22, 2009
agent91
  • 2100 Answers
SOURCE: how to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
Posted on May 03, 2010
  • 1788 Answers
SOURCE: Just got Raleigh Detour 4.5
Where did you buy the bike? Any dealer who sells a bike is more than happy to instruct you on the use and maintenance of it. I will give you a brief, lesson-left hand controls the front brake and gears, right hand controls the rear (R=rear, easy way to remember). Front derailleur is the ranges 1 (closest to the bike are always easiest) and the farther away from the frame get harder but make the bike go faster. The rear derailleur has more than likely 7 cogs again same rule as above. So always pedal forward and do not go small gear in front to small gear in rear, & large gear in front to large gear in rear because your chain will stretch from too much stress and it doesn't do you any good.
Do not pedal backwards because unless your chain is directly on the correct gear you will chip teeth on your gears.
But, do go for lessons on your bike, to learn maintenance tips and how remove your wheels, etc.
Remember bikes are not toys, they are machines and need to maintained to get the full enjoyment out of them.
Posted on Sep 25, 2010
Testimonial: "Thanks ..dealer spoke with so much info ..missed some I'm afraid..willl go back now that I have special info needed..."
Coachphil
  • 347 Answers
SOURCE: I have an AVANTI Blade
This is a solution I strongly recommend you take into a bicycle shop. It will either be a problem they can fix (needs to be seen to properly diagnose) or a possible warranty issue which they would be the ones to take care of anyway.
The problem could be anything from an adjustment, which is far to complicated to explain with those hubs up to a broken part.
Posted on Jan 06, 2011
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
I've pulled my raleigh shimano 21 bicycle apart and I've forgotten how to put it back together
"Shimano 21" doesn't really narrow it down much.
What exactly are you needing instructions for? Most bikes are just static frames with a bunch of aftermarket (Shimano, for example) stuff hung on them.
Everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the individual manufacturers' websites.
Places like http://www.parktool.com/blog/repair-help document many of the repair and adjustment procedures.
Google will find tons of How-to videos for assembly and adjustment.
You might find a Raleigh-specific manual for your bike here...
http://www.raleighusa.com/downloads/
Apr 26, 2011 | Shimano Cycling
Just got Raleigh Detour 4.5 Women's with Shimano EF-50- EZ shifter and no clue how to use all speeds and levers??? Help...any manuals???
Sep 25, 2010 | Shimano Cycling
Turbo R-24 Model Empire 24 Inch Men&s Bike how many if any gears does it have shows to have ◦Shifters: Shimano tourney index but what does this mean. Sears can't answer
Count the number of sprockets you have up front, then count the number you have in the rear, Multiply, 3 x 6 = 18 speeds. 3 up front, 6 in the rear, or 2 up front, 5 in the rear, 10 speed. Etc, they go as high as 21. You might only have one in the front.
To shift, you have to be peddling, get the bike going, put the chain on the middle or the biggest sprocket in the front, move the left thumb shifter to do this, do not let the chain rattle, make it a clean shift and don't let it klik or rub. Then put the chain on the biggest one in the rear , without any rubbing, chattering, slipping, etc,with the right shifter, now you are ready to take off easily, when you get going and the pedals get too easy and go faster, shift the rear to the next sprocket down, then again, then when you are coming to a stop, down shift the rear sprocket back to the biggest gear and you will be ready to take off again easily. A few tries, you will shifting like mario andretti. Hope this helps.
Jun 16, 2010 | Empire Turbo TURBO BICYCLE R-24 MODEL...
How to use thumb shifters on a 21 speed Schwinn Highplains bike
May 03, 2010 | Cycling
Hi, Just bought a new bike with shimano tiagra gearing. However the gear shifters doesn't seem to work. There is no movement in the cables when I try to shift gears. Do you have any idea for a quick fix or...
You don't mention which shifter(s) malfunction or if you're even pedaling the bike while shifting (I make NO assumptions).
If you operate the inner shift lever (NOT the brake lever) on each side through several clicks that should RELAX any tension in the shifter cables. Then if you pick the bike up and pedal it forward a couple of turns the front shifter should drop the chain the the lowest chainring and the rear derailleur should shift out the the smallest cog.
With the bike suspended (say, hanging from a low tree branch by the tip of the seat) you should be able to turn the cranks and manually pull sideways on either exposed shifter cable where it runs down along the downtube then release it.
This should cycle each respective derailleur through its entire range. If the cables don't travel sufficiently in this manner, the shifters will never make them do it either.
Perhaps you could CALL the Bike Shop and they would talk you through a quick operational check.
Apr 27, 2010 | Shimano 24 Speed Road Racing Bike Bicycle...
7 speed alivo shifter no down shift
Hi log onto shimano.com and you will find what you are looking for
Oct 15, 2009 | Mountain Shimano Alivio Front Bike...
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
Cycling Logo
179 people viewed this question
Top Raleigh Cycling Experts
dante
halyarbro
Level 1 Expert
Are you a Raleigh Cycling Expert? Answer questions, earn points and help others
