Question about Canon CanoScan 4200F Flatbed Scanner
Clean inside glass - Canon CanoScan 4200F Flatbed Scanner
    Problem Solver:
  • 18 Answers
You wish to clean inside (under) the platen glass of your Canon 4200F Scanner; first I have to tell you that this is a pretty delicate operation. Make sure you see real dust with the help of a flashlight. Consider there could be another cause for a poor quality scan.
So why fix it if you don't have to?
Maybe you should have it serviced by a Canon technician. But if you're too far away and concerned to ship it, here is how I just did a few days ago.
You shall need the following tools
Safety glass
Safety gloves (optional)
2 flat screwdrivers (small)
1 Phillip screwdriver (#2)
1 Smaller Phillip screwdriver
Tweezers
1 flashlight
1 sheet of paper (to be recycled) cut into small folds (8 or less)
A clean cotton rag
Window cleaner (your favorite)
I highly recommend you first put your safety glasses and gloves! Make sure you have all your time. It may take a good hour to get through. Read all of these instruction before so you have a better understanding of how this works. A good tip is to remove any part slowly enough to notice and remember how they held together. In doubt use a camera or your phone and take pictures before you start.
1. Unplug both cables.
2. Bring your scanner into a well lit area. Place it horizontally (as in a landscape pictures) the hinge cover side being on your right.
3. Pull the cover up. It should stay open. There are 2 screws (Philips) on top hinge side, between right end of glass and hinge. Unscrew both. No need to pull them out.
4. Unscrew the third screw (center) with smaller screwdriver and pull up a tiny cover. There is a fragile flat ribbon cable (1/4 in). Pull it out gently. Close the top cover.
5. Let it rest flat.
Now you are in the delicate part of this operation! :-) There is no other screw than these 3 ones you'll need to touch.
6. Since all (3) screws are completely loose, you shall feel the top is showing a slight «will» to lift. Using your two small flat screwdriver GENTLY pry OUT the BOTTOM part of this «oyster shell» starting UNDER the HINGE side, alternating with both screwdrivers, one the edge facing you. Keep it open with folded piece of paper or anything else so it does not clamp back. Do the same on the opposite side.
In other words, the top parts is now held to the bottom part with nothing else than these fragile minuscule edge claws. GENTLY slide off RIGHT the cover and the glass together, looking how the glass is inserted under on the left side.
If there is a too much resistance, one of the screws may not be loosen enough or there may be a claw still pulling.
Now you do your cleaning. But you are not over yet!
PUTTING IT BACK TOGETHER:
You should be able to reverse the operation that you just did.
Slide left together the glass and top, carefully clamping down the top to the bottom from left to right, exactly as it was. Check so you don't see any open space in between.
If not: go back.
Using your tweezers gently connect down you flat ribbon cable into its connector. Place the small cover and the only small screw.
Put back the 2 screws next. Bring back your scanner to your computer. Reconnect your 2 cables.
IF, you get an error message, first check your USB cable, then the flat cable connection!
It worked just fine for me.
Posted on Apr 28, 2015
How can I clean the inside of the glass on a Lamont 3400 oven door
Hello, Johnny -
The instructions I found for cleaning the glass inside an oven door are generic and not just for a Lamona brand oven. (You did mean "Lamona" and not "Lamont", didn't you?)
See the instructions here:
https://www.mom4real.com/how-to-clean-in-between-glass-on-your/
Read through the instructions, in full, first.
This is a link to other instructions in video format:
https://www.todayshomeowner.com/video/how-to-clean-inside-the-glass-on-an-oven-door/
Best wishes.
Mar 07, 2018 | Ovens
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
Want to clean inside of glass
there is no way to clean the inside of the glass. The CRT is a completely sealed unit and unless there has been a malfunction, there should be nothing on the inside of the glass. The way CRT's work is a photon gun shoots electricity at the inside of the screen, which is coated with a layer of phosphur. this excites the phosphur and makes it glow with color, forming the picture that you see. Even if you could get at the inside of the glass, you wouldn't be able to clean it becuse you would wipe away the phosphur coating.
Mar 21, 2011 | Gateway VX 720 17" CRT Monitor
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
Cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Aug 31, 2008 | HP Photosmart 2610 All-In-One InkJet...
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Glass cleaning
inside? it sounds like you want to take it apart that's the only way to get under it
Dec 01, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
Canon CanoScan 4200F Flatbed Scanner Logo
726 people viewed this question
old marine
old marine
