Question about Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum
The spray goes everywhere but where I want it to.It makes such a mess,what do I do?
  • Official Brand Answer
  • 315 Answers
Hi Fred. It's not fun having to clean up a bigger mess than what you started with. I'm sorry you're having difficulty.
You may want to contact us for additional assistance. Here's the quick link: http://www.bissell.com/contact-us/?cid=ccsocial
Posted on Aug 02, 2013
LIttle Green Bissell Water goes directly to collection tank, won't spray
Had a problem with mine not spraying, took ot apart and the heater for the solution was plugged with scaling, cleaned it up and works the very best now. As far as clean water going directly into the collection tank, sounds like the little hose may have a break or a leak in the vacuum hose.
Mar 14, 2018 | Bissell Vacuums
In using Kirby portable cleaner the air blows the foam everywhere and not much on the object I am cleaning
you need to use the small round suds nozzel, this will create a fine foam, spray the foam into a basin, the use the upholstry brush to apply to the stairs or chair.
Aug 16, 2017 | Kirby Vacuums
Bissell 1623 sprayed used water from tool
Hi Beverley, you may want to have your machine inspected by a Qualified Technician at one of our Authorized Service Centers.
Here's a quick link to locating an Authorized Service Center in your area. http://www.bissell.com/service-centers/?cid=ccsocial
Jan 26, 2013 | Bissell 1623 Steam Cleaner
I have a bissell pro heat 2 it will spray water through hand held pipe system but wouldnt spray from main capet brush area can you help me please
Ours would not spray water either, after messing with it for ages I discovered the round black housing that the tank locks into where the water flows out of the tank was loose. So I held the housing from underneath while seating the tank & it started working. It's very flaky & a lousy design. Good luck.
Jan 16, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Water is leaking out of the upholstery cleaner
Might the button be stuck a bit? We had this problem and rinsed the brushes out and cleaned the connector area with a damp paper towel. Had to push the button in and out several times to be sure it wasn't sticking. Also, when the hose is docked found it tended to hit the docking station and would spray everywhere! Had to turn around the hose w/ the button so it would stop spraying everywhere. Hope this helps.
Apr 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I hook up my Kirby Ultimate G for upholstery shampooing?
Hooking up the foaming device simply blows foam into the job. Here is a shortcut which I find more convenient on my G4 tools. If you have the rotary upholstery shampoo kit, you can just attach the rotary tool to your hose. Then mix your kirby suds into a household spray mist bottle. If you happen to have a mist bottle with a screen on the intake straw it will foam your suds not quite as well as the kirby device, but this way you can store the suds in the spray bottle for future quick use.
kirby suds are designed to be used as foam not liquid so a foamer in the spray bottle helps the process. You do not want to soak the furniture, just apply a light mist and scrub with the air driven shampoo tool on the hose. Then allow to dry and vacuum 24 hours later.
Sep 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaks out the bottom
ther is supposed to be a black rubber gasket with a cone/triangle looking thing that may not be in place
Jul 01, 2009 | Bissell 1400 Little Green Pro Canister...
Connect hose to shop vac
Perhaps you should contact your contractor and ask him for assistance before you destroy his property or make a mess of yours.
Jan 22, 2018 | Shop Vac 201-13 Wet/Dry Vacuum
Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum Logo
51 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
