Question about ZEEPAD New 7 Inch Android 2.2 Via8650 Epad Tablet Pc 3.0 Camera, External 3gwifirj45two Point Touch Screenflash 10.1 Leather Case And Car Charger Silver
Tablet reset Android Icon is on its back with its stomach hatch open..
Keypad RCA tablet not working
Ah, I see. The perils of vague questions :>)
Do a Factory Reset. It clears everything off it but reloads the operating system.
  • RCA Factory Reset & Reboot Unlock - YouTube www.youtube.com/watch?v=ttvFDFqH5r0
    • BY RC JR
    • 3 MIN
    • 293K VIEWS
    2014-09-19 · Video embedded · Simple video on how to hard reset RCA Android Tablet. Unlock your Tablet PC, if you have forgotten the password, froze or stuck! Is ...
  • How to hard reset 7" RCA TABLET? - How Android Forum www.how-android.com/thread-how-to-hard-reset-7-rca-tablet Since last week my 7" RCA TABLET tab is doing wrong activity like when I press on any icon then it open's the any other app and it's open some apps automatically so I ...
  • http://www.bing.com/search?q=RCA+tablet+hard+reset&qs=n&form=QBRE&pq=rca+tablet+hard+reset&sc=1-21&sp=-1&sk=&cvid=4D033AEF718C4119A6973A0BC0675E61
    May 17, 2016 | Tablets & eReaders
    How I reset my SVP 9" Android tab
    hi open up youre icon page look for settings or tools click on / a page should come up with all the info on youre tablet scroll down to back up & reset & follow instructions...good luck
    Aug 20, 2015 | Tablets & eReaders
    Allwinner a20 not booting up
    Just do a factory reset and prior that take backups of the desired media
    your tablet would work as brand new after factory reset
    May 22, 2014 | Sinvigo Allwinner A20 1.2GHz CPU Dual...
    Pandigital novel
    Looks like your tablet wilnot reboot properly after the Factory reset, did you do a firmware update before? If so, try another firmware and try again. Gr peter
    Apr 23, 2014 | PANDIGITAL Tablets & eReaders
    My tablet comes on but all I get is Android flashing across the screen what should I do
    Do a factory reset. Turn the tablet off. Wait 10 seconds or so. Hold down volume down button while pressing the on button. Keep holding down both buttons until you see an android icon. It may be laying on its back with a red exclamation mark over it, like I saw. Once you see the icon, let go of the buttons and press the "back" or return button. This should bring up a list of options. You can scoll through the list by using the up or down volume buttons. I picked the option to delete all user data, which basically will set the tablet back to factory settings, like when you first got the tablet. Once that is complete, reboot the tablet.
    Jan 10, 2014 | Tablets & eReaders
    Zecki tablet wont go past the android screen after reset from settings screen
    I did a factory reset on a Bell & Howell C714. I would think that the process would be similar. Turn the tablet off. Wait 10 seconds or so. Hold down volume down button while pressing the on button. Keep holding down both buttons until you see an android icon. It may be laying on its back with a red exclamation mark over it, like I saw. Once you see the icon, let go of the buttons and press the "back" or return button. This should bring up a list of options. You can scoll through the list by using the up or down volume buttons. I picked the option to delete all user data, which basically will set the tablet back to factory settings, like when you first got the tablet. Once that is complete, reboot the tablet.
    Dec 10, 2013 | Tablets & eReaders
    Tablet freezes on boot up at android screen
    Mar 24, 2013 | Iview 760TPC Android Tablet, ARM Cortex-A8...
    How to master reset emerson 4.3 " internet tablet model em543
    When i do this a green monster shows with the door open to his stomach with a red sign on ot what does this mean??
    Jan 05, 2013 | Tablets & eReaders
    What does it mean when android robot is laying on its back
    I am giving you an example with an Motorola Tablet. I'd try clearing your cache partition, you can get to the android recovery with your buttons.
    1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
    2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
    3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
    4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
    5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
    6. Use the volume buttons to move up and down through selection in this menu.
    7. Using the volume down button, scroll down to "Wipe data/factory reset"
    8. Tap Power hard key to select option.
    9. Scroll down to select "Yes, delete all user data".
    10. Tap the power button to select. Wiping and formatting data will take a few minutes.
    11. You will return back to the Android recovery screen menu.
    12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
    As you're going through the options don't do the factory data reset, look for wipe cache partition then follow the instructions to reboot.
    Hope this helps!!! Let me know if you need more help
    -Nadeem
    Dec 25, 2012 | Ematic 7" eglide Pro Tablet
    ZEEPAD New 7 Inch Android 2.2 Via8650 Epad Tablet Pc 3.0 Camera, External 3gwifirj45two Point Touch Screenflash 10.1 Leather Case And Car Charger Silver Logo
    Top ZEEPAD Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a ZEEPAD Audio Player and Recorder Expert? Answer questions, earn points and help others
