Question about Seaga Manufacturing SM26 Commercial Refrigerator
Compressor won't start...cap replaced - Seaga Manufacturing SM26 Commercial Refrigerator
  • Bob Whitman Aug 01, 2013
    Any source for schematic??
My ac fan works but the compressor won,t kick on
The fan on the condenser or air handler? Check the capacitor on the condenser. If you don't have a meter that does uf you can take the amp draws of the comp multiplied by 2650, divided by the voltage between com and herm on the cap. If cap is good be sure compressor is not off on thermal overload, cool with water hose, careful to not soak electrical. If not hot and cap good , try hard start kit. If still no compressor ,ohm compressor, com to start plus com to run should equal start to run on ohms. Hope this helps.
Apr 04, 2016 | Heating & Cooling
I have a Carrier Air V air conditioner on which the compressor won't start. You can hear it try repeatedly, but no luck. The fan does work.
CHECK AMP DRAW IF ITS HIGH BAD COMPRESSOR WINDINGS, MAKE SURE YOUR GETTING PROPER VOLTAGE DOES CAP HAVE A RUN AND START SIDE CHECK BOTH. START CAP COULD BE BAD.
Apr 14, 2012 | Carrier Heating & Cooling
Hooked up new 4 wire fan 2 condensor with a new 2 cap fan runs fine but no compresor?installed as was told with nothing runnng 2 the new cap but the brown wires but compresor isnt kicking on
The compressor could be bad there is two ways to tell with an ohm meter check each lead off the compressor and to ground for continunity or a megometer . You can always try a hard start kit. It is a super capicator that multiplies starting voltage. Have you checked all connections? There might be a low\ high Pressure switch in the referigent lines if that is bad it won't allow the unit to start. Also is it a heat pump or straight a/c the heat pumps have circut control boards in the unit that control everything
Aug 07, 2011 | Goodman CLQ36AR49 Air Conditioner
Fedders 208/230 split system w/ dual cap , compresser runs but fan wont unless you give it a push , compresser won't restart if relay is hot
All kinds of stutt happens when you dont have a condensor fan motor. You need to change the run cap on the motor.
Aug 06, 2011 | Heating & Cooling
How do you add refrigerant.
If you follow the lines coming from the A/c compressor, you will find a red cap on one line and a blue cap on the other line. The blue cap is the suction side. Remove the blue cap. You can buy recharge kits at the parts store that have a line and tap included. You just couple the line there, open the valve on the freon can and start the engine. Run the a/c on high. Be careful not to overcharge the system. If the belts start squeeling, that will indicate too much freon in the system and a high presure situation.
May 12, 2011 | 1999 Buick Century
Compressor cycles on for about 16 seconds and off for about 1 or 2 minutes
your compressor is bad or the start switch is bad. the start switch is on the compressor follow the wires to the compressor there will be a plastic cap held on by a flat spring wire remove the cap the starter is about as big around as a nickel and will be connected to one of the 3 compressor studs. If its the compressor you will be better off replacing the unit.
Aug 08, 2010 | KitchenAid (KSRD22FKST) Side by Side...
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
Compressor tries to kick in but then stops.
it is a hard start compacitor, the unit is not supposed to have three compacitors.
Apr 11, 2009 | Coleman Mach 15 Air Conditioner
Seaga Manufacturing SM26 Commercial Refrigerator Logo
15 people viewed this question
Top Seaga Manufacturing Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Seaga Manufacturing Refrigerator Expert? Answer questions, earn points and help others
