Question about Lexmark Wheelwriter 10 Series II Typewriter
When go to print on wireless system states not communicating, run trouble shooter which states that printer not on but printer is on with green wireless light lit.Printer is all in one S605
How do I down load to be able to use my priter with the computer
Posted on Oct 24, 2013
There is a problem communicating with the printer
Please download the firmware update from the Lexmark website www.lexmark .com and install the patch http://bit.ly/pWGkeE after updating.
Jul 12, 2012 | Lexmark Interact S605 All-in-One Color...
Unable to communicate thru WiFi to print
A solid green Wi-Fi light indicates that it is connected to a wireless network. An orange light indicates that it is not connected to a network.
Another way to determine if your printer is connected to your network is to print the wireless network setup page. From the printer operator panel, press the Setup button (wrench icon) > Network Setup > Print Setup Page. Your printer will then print the network settings. Check the SSID, signal strength, or trouble code.
A quick fix to this problem (especially if your printer was working fine before with your wireless network) can be achieved by resetting the printer and/or rebooting the PC.
Oct 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have a hp officejet 6500 e709 all in one printer, i have been able to communicate without any problems wirelessly until recently. i had an error saying ink was low and had trouble printing, i assumed it...
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issue.
Dec 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
It blinks orange
The information below (could not copy illustrations) is available from:
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X4650&segment=SUPPORT&userlocale=EN_UK&frompage=null#1
I did a searcfh for 'blinking orange light' in the Got a Question field.
The Wi-Fi indicator light gives information about the status of the printer.
NOTE: Most wireless communication issues are a result of the following:
  • RF interference or wireless signal quality.
  • System of software firewall applications blocking crucial Lexmark software and ports.
  • The router has been reset. A different or new SSID(network name) and passphrase on the router creates a mismatch to those originally configured on the printer. You will need these router settings to reconfigure the printer using the included Setup Utility or Setup Assistant.
  • The printer has been turned OFF for period.
Use the table below to help determine your printer's current status, and refer to the linked articles for additional assistance.
Wi-Fi Indicator Possible communication states
Related Links
Important! This article was disigned for previous generations of Wireless-equipped inkjet printers. Not all article links are current, but they may still provide useful guidance.
Off
"I have no wireless capabilities."
  • Initial power-up state.
  • The INA* is not present.
  • The INA is not properly connected
  • The printer power is off
  • Hardware failure
  • USB connection with printer that lacks wireless print server.
Contact Lexmark if this remains a problem. See Still need help? below. pattlnk_4182007_1318-aniorange.gif
Blinking orange
"Printer is trying to connect wirelessly"
  • The INA has been configured for infrastructure, but is not linked to an access point
  • There is a security setting mismatch between access point and router.
  • Interim negotiating status while performing setup procedure.
  • Out of range or interference between printer and access point.
  • Printer unplugged for an extended period of time may cause this to happen.
Click here for 'Printer Not Found or here for an alternative article on 'No communication' issues.
Click here for an article on Signal Strength. NOTE: This article pertains to the X3500-X4500 Series printers but it is valuable for ALL wireless products.
If you are really unsure what has happened:
  • Make sure the computer is communicating over the network.
  • Reset your wireless router (AP) by turning it OFF and ON or
    remove the power supply from the back of the printer and then plug it back in.
  • Follow this link to the Wireless Setup Utility or Wireless Configuraton Utilty to reconfigure the printer.
Solid orange
"Printer is not communicating wirelessly"
  • The printer is brand new and has never been configured.
  • The printer is connected via USB cable.
  • The printer is in the middle of being configured.
  • The INA is waiting for an ad-hoc (peer-to-peer*) connection.
* Computer to printer communication without the use of a router.
Need to configure:
Windows XP/Vista
NOTE: These are examples only.
Infrastructure (most common) Click here. Ad hoc Click here.
All-In-Ones (AIOs), also known as MultiFunction Printers (MFPs):
Infrastructure Click here. Ad hoc Click here.
Windows users: The light will not turn green until after you have removed the installation cable!
Macintosh X.3 and X.4
AIOs (MFPs)
Infrastructure Click here. Ad hoc Click here. pattlnk_4182007_1320-grnmedallion.gif
Solid green
"Printer is connected wirelessly"
  • The INA has been configured and is connected to an access point.
  • The INA is connected ad hoc.
  • For a 'Communication error' with a green light, click here.
  • For a 'Communication error' only after the printer comes out of power saver , follow the below links:
X4800 Series - click here.
X6500 Series - click here.
X7500 Series - click here.
Blinking green Printer will flash green during a code update. Click here for an article describing how to update network firmware. Or, click here for further firmware code update information.
NOTE: This indicator should not be seen often.
INA = Internal Network Adapter
Trust this is helpful. Note you can download updated drivers and use the Wireless Troubleshooting Guide from this site.
Please vote. :)
Dec 12, 2010 | Lexmark X4650 InkJet Printer
My new lexmark pro805 printer was initially saying offline when I tried to print. The wireless indicator is green but even through an ethernet connection I get that it is having trouble communicating. I...
It's possible that you have not added a network queue to be able to print. You can add a network queue by going to System Preferences then Printers and Fax then add a printer and on the Default 'tab' your printer should be listed. Click then add that printer then print.:D
Mar 14, 2010 | Office Equipment & Supplies
CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
Jan 22, 2010 | Lexmark X4550 InkJet Printer
I am running Vista Home 32 bit and have a Lexmark X4850. It will not communicate with the printer from either wireless or USB. I got it to print a test page from both, but that was one time after a...
Have you talked with Lexmark Technical Support? I suspect you may have to escalate this beyond level one. Vista on Mac is likely to have issues that differ from other Vista environments.
Sep 24, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Printer offline
go through control panel, printers, and select your printer..right click on it..bring it back online..
Feb 17, 2008 | Canon BubleJet i965 InkJet Printer
Lexmark Wheelwriter 10 Series II Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
