Question about Stoves Ovens
Frigidaire stove stop working and displays code F6. What does that mean? How do I fix it?
  • 39 Answers
Replace EOC. Or control. Lard. Sorry.
Posted on Oct 18, 2013
4 Suggested Answers
SOURCE: What does F10 display on my stove mean? Frigidaire Model PGF355DS
my frigidaire oven keeps flashing f10 and turning off
Posted on Aug 21, 2009
  • 30 Answers
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Posted on Nov 13, 2012
    Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
    answered on another appliance site..
    https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
    the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
    Feb 12, 2018 | Frigidaire Ovens
    Frigidaire FEF366CCB classic series electric oven. While I was away the oven stopped working. No heating elements in the oven or stove top at all work. The EOC still shows time, no fault code. Ideas?
    check breaker or power feed my not be getting correct power to the unit may only be getting 110v which electronic circuits work on instead of the 22ov that the elements and coils work on
    Oct 06, 2016 | Frigidaire Ovens
    Frigidaire stove error code
    F68 = Power Line Failure. Turn power off for 30 seconds. If this does not correct it, check the electrical supply for proper voltage, ground, and polarity, if all of this checks ok replace the EOC-Display board
    Aug 08, 2014 | Frigidaire Gallery 30 " Stainless Steel...
    Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
    The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
    GENE
    Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
    Hi, My oven has been beeping a F10 error code for some time now, and I would like to know how I can fix this problem?
    This is from Frigidaire website
    These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
    • Press STOP/CLEAR to clear the display and stop the beeping.
    • Reprogram the oven.
    • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes to turn it back on.
    If the code is still displayed after you've followed these steps, contact your local authorized service provider.
    That is the best answer I can give. I hope it helps. I don't know what the code is, but it only gives this answer.
    Joe
    Aug 30, 2011 | Frigidaire FGB24L2A Gas Single Oven
    My general electric stove oven does not turn on.. code come out f7 and 5 6..what does t mean
    F4
    or
    F5 Humidity sensor open or shorted Replace humidity sensor. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe.
    Nov 06, 2010 | Ovens
    F7 error code- what does this mean?
    Frigidaire / Westinghouse / Tappan / Gibson
    Oven Fault Codes
    Display Condition Remedy
    F0 & F1 EOC failure Replace EOC
    F2 Oven over heat Defective Sensor or EOC
    F3 Oven Sensor Open Replace Sensor
    F4 Shorted wire or Sensor locate short and correct it
    F5 EOC failure Replace EOC
    F6 EOC failure Replace EOC
    F7 EOC failure Replace EOC
    May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
    Apr 02, 2009 | Ovens
    "F1" error code on Magic Chef gas range Model 3488XRA
    the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
    Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
    Open Questions:
    Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
    Feb 24, 2018 | Stoves Ovens
    Ovens Logo
    35 people viewed this question
    Top Stoves Ovens Experts
    ashburton
    Dan Webster
    Dan Webster
    Are you a Stoves Oven Expert? Answer questions, earn points and help others
