Question about NEC Lands Phones
Phone is stuck displaying user program mode - NEC Lands Phones
HOW TO OPENLINE HITACHI CDMA W42H???
All type of phones (old modeles):
NAM programming: 47*869#08#9
Test mode: *759#813580 or 5809540*45680
exit test mode - 02
A-Key: menu + 0, code 25##
Samsung A500
1. Enter ## and the 6 digit OTKSL
2. SERVICE MENU will appear and 1.Basic will be highlighted
3. Press OK
4. Device will display NAM CDMA/ Phone Number
5. Enter 10 digit MIN
6. Press OK (3 times)
7. Display will return to Service Menu. Press END.
8. Programming is complete
Samsung N240 and N400
1. Enter ## and type in the 6 digit OTKSL
2. The display will show SVC MENU and 1. Phone Number
3. Press OK
4. Enter the 10 digit MIN and press OK
5. The display will show NAM with Home SID on the second line (Note: SID is no longer used)
6. Press OK
7. The display will return to the SVC MENU
8. Press END to complete the programming
Samsung Uproar
1. Press MENU key
2. Enter 9 2 0
3. Enter the OTKSL
4. At SVC Menu screen press OK
5. Enter MIN and press OK 4 times
6. Enter SID (4654) and press OK
7. Press END key
Samsung N300
1. Press ## followed by the OTKSL
2. SVC menu will be displayed
3. Press 1 for Phone #
5. MIN that was entered will be displayed press OK
6. SVC Menu will display press 3 for NAM
7. Enter the 4 digit Home SID press OK
8. Press END and handset will power cycle
Samsung i300
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. ENTER OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
Samsung A400 and A460
1. Enter ## and OTKSL
2. Press 1 for Basic at MENU (1 of Phone # when using the MSL)
3. Enter 10 digit MIN and press OK
4. At 1.Basic Menu press the END key
5. Handset will power cycle
Samsung 3500 8500 6100 N200
1. Press MENU
2. Press 6 0 (3500) 8 2 0 (8500/6100/N200)
3. Enter OTKSL
4. Press 1 at SVC MENU Screen
6. Press OK 4 times
7. Enter SID (4654) and press OK
8. Press END key
9. Programming is complete
Qualcomm:
QCP-800 programming: menu + 3 + 0.
SPC: "000000" or may be other SPC typed by user.
QCP-820/1920/2035: type "111111" and press Jog Dial.
Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user.
QCP 1960 and 2760
1. Press softkey under the work MENU
2. Press 8 0
3. Enter the OTKSL
4. Press softkey for OK
5. Enter MIN and press softkey for OK
6. No SID is require for this handset
7. Press softkey for EXIT
LG:
LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user
A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key
LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user.
A-Key: type 2539** and enter A-key
LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user.
LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user.
LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200
1. Press ##
2. Enter the OTKSL
3. Scroll to SAVE and press OK
4. Scroll to MIN and press OK
5. Enter 10 digit MIN scroll to SAVE and press OK
6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete)
7. Enter SID (4654) and scroll to SAVE and press OK
LG5350
1. Enter ## and enter the OTKSL and press the left soft key under the word clear.gif
Mar 01, 2012 | Cell Phones
How to change name display
There is no user programmable way to change the name display on your phone. On NEC systems, you have to go into programming mode and access the memory block for extension names. Sorry.
Jun 01, 2011 | NEC DTH-8D-1 Corded Phone
How do I manually enter phone numbers into the "speed dial" directory of my Toshiba FD-9859 cordless telephone?
Welcome to Fixya
To program a speed dial on your phone, enter programming mode (press #9876 on your phone). The phone will display "USER PROGRAMMING MODE." Press the Spdial button, enter a speed dial number (100-119), 9 plus the phone number you wish to dialed (1-213-555-1212 for example), then press the Spdial button one more time to lock it in. To use a programmed speed dial, just press the Spdial button plus the number.
Thank you for using Fixya!
Apr 06, 2011 | Cell Phones
CHANGE THE TIME ON MY PANASONIC 7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Mar 14, 2010 | Panasonic KX-T7453 Corded Phone
On a Toshiba DKT3020-SD, how do I enter the User Programming Mode. I tried pressing #9876 but it did nothing.
There are two programming modes. One is User the other is system. for user programming press 3,6,9,hold at same time. For system type hold *#*#1*2*3* and enter password 0000
Feb 04, 2010 | Toshiba DKT3020SD Corded Phone
Extention Display Name
This detailed instruction is not in the small book that came with the phone. It will be found in the binder or full sized publication titled “User Manuel’ for the models KX-TD816 and KX-TD1232 that came with the phone system.
You will want to use the overlay that DID come in the smaller book. You will place it on top of the buttons and it will provide programming commands listed in the instructions.
Page 71 has the “Getting into programming” details.
[Program], **, 1234
Now you are in user programming mode.
Page 87 will instruct you how to program names.
Press 004, [Next], [jack number] (ext 101 = jack #01-1, ext 102 = jack #02-1 ect…)
Once the jack and the old name are displayed, press [Clear] and then start pressing the letters according to the “Overlay”. (3 = 3 D E F) press the S-button that displays the correct character. S-buttons are the 3 buttons directly below the display. When you are done press [Store] and you can press [Next] to se more jacks or just exit by pressing [Program].
Jun 20, 2008 | Panasonic KX-T7453 Corded Phone
Setting up speed dial numbers
�� To enter User Programming Mode, press the Program button ...or dial #9876. "USER PROG MODE" appears on your LCD. The Program LED is steady green. �� To exit User Program Mode, press Program … or go off- and on-hook press #9876. Note A IPT equipped with a headset adapter ignores the hookswitch. It can only exit User Programming by timing out (approximately 15 seconds).
May 05, 2008 | Toshiba DKT3020SD Corded Phone
Stuck on Night Mode
Your phone can work on different Panasonic phone systems that program differently. I would need to know the model number of your phone system to look up specific information.
Until I get that info from you. Most systems can only be turned on and off from night mode at one phone station (usually the operator) but others will let you program a programmable key on any phone to do this. It's also possible to enter a function code from any phone on some systems.
Does it say Night Mode on a display? How do you know it is in night mode? If it is on a display, is it on all the displays or just one? If just one then that is the phone that can turn it off.
Nov 19, 2007 | Panasonic KX-T7630 Corded Phone
Mysterious -PRO- message on the 26510
Fred,
Could the "PRO" stand for Program Mode? Is there a Program button or selection under Menu in which you can shut off a Program Mode?
Nov 10, 2007 | Northwestern Bell EasyTouch 26510 Corded...
Panasonic KT-T7431
Hello. You can change the time when you enter the User Programming Mode (this information is found in the Digital Super Hybrid System User Manual, not in the manual for the phone):
Press PROGRAM + ** + User Programming Password (default is 1234)
Press 000
Press NEXT (Sp-phone button) : The date will be displayed.
Press NEXT (Sp-phone button): The time will be displayed.
Use the <-- (Conf button) or --> (FWD/DND button) to move along the line and keypad to update
Press Select for AM or PM
Press Select for 12 or 24 clock hour
Press STORE (Auto Dial button)
Press END (Hold button) to exit
Hope this helps you all!
Sep 24, 2007 | Panasonic KX-T7431 Corded Phone
Lands Phones Logo
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
