Question about Polaris Pb4 - 60 Booster Pump
Incoming wire has red,black,white. What goes where
  • 372 Answers
One of those wires should be green (ground wire). The two wires that are not the ground wire go to the two terminal posts, either way, and the ground screws directly to the motor housing above the terminals. Should be a green screw there. Was this electrical used on a 2 speed pump before?
Posted on Aug 02, 2013
A.O. Smith 1/4 hp 115v red black blue and white
Not sure what wires you are talking about. Normally on a 115volt motor you will have L1 and L2 and a green ground screw. Black or red goes to L1 and L2 (either one). White goes to either L1 or L2 (either one) and the green ground to the green ground screw. These would be the incoming voltage wires.
Sep 13, 2014 | Pool & Spa
Installing replacement Polaris booster pump pb4-60. Removed old wiring without checking to see what went where. Dumb. incoming wire has a red, black , white. What goes where?
if 220 volt either red or black to l
1 the other to L2 white to ground or case make sure to measure between red and black you should get 220 volts ac
Aug 01, 2013 | Polaris Pb4 - 60 Booster Pump
Hunter original old thyme model 22272 wiring diagram
the (white) wire is likely the neutral, red - low speed, blue - high speed.they would typically be connected thru a selector switch. however, best guess is that white would hook to incoming white neutral, and blue (or red, but not both at the same time) would hook to incoming black (hot) wire.
Jan 26, 2013 | Heating & Cooling
Wiring diagram for a p i r to a light
They all wire the same. The black wire on the PIR connects to the incoming (usually black) hot or switched wire. The red wire on the PIR connects to the light(s), usually a black wire. The white (neutral) wire from the PIR connects to BOTH the incoming white wire and the white wire that goes to the light(s).
Jan 17, 2012 | Home
Lost wiring manual
The wiring manual is no longer available for that model from Intermatic. However, I can tell you that the black wire on the photo cell connects to the incoming hot wire, (usually black). The red wire on the photo cell connects to the wire that goes to the light (usually black). The white wire on the photo cell connects to _both_ the incoming white (neutral) wire and the white (neutral) wire that goes to the light or load.
Jan 22, 2011 | Intermatic K4221C Photo Cell Control 120 V...
The 3-way dimmer switch has 4 wires; 1-red, 1-yellow, 1 green and 1 black. Hot wire coming in is black, ground is bare and neutral is white. Wires going out are red,black,bare and white. What does each of...
Incoming white - outgoing white This is the neutral, which just passes through without connecting to the switch
incoming black - switch black the hot wire provides power to the switch
switch red - outgoing red a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare the switch is grounded and it passes through
If this was helpful, please vote.
Mar 21, 2010 | Cooper Wiring Devices Three Way Grounded...
I need to wire a combination GFCI/switch using incoming 4 wire (red, white, black, bare) and outgoing 3 wire (red, white, bare) replacing an existing switch. How do I wire this properly??
Can you tell me where the outgoing wires are going to. Bare wire is ground goes in green color screw, white wire is neutral and goes in silver color screw, black wire is hot or live and goes in gold color screw. It is difficult to help you with little information. how do you know what is incoming and outgoing.
Mar 06, 2010 | Leviton 8299 Combination Switch / Smart...
The sensor has 1 red, 1 black, 2 white wires?
BROWN = PHASE BLUE = NEUTRAL.
European code.
BROWN = BLACK WHITE = BLUE
Feb 06, 2010 | Garden
Installing remote control ceiling fan
Your black wire is line and red is load. So your incoming power hot goes to black and out going power to fan connects to red. White is wired with all three whites together and same with green.
Aug 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Cooktop wiring
usually black(120v) white (n) and red(120v) bare wire to ground, but if htat what yo got and your sure of incoming voltage, blabk to black , red to red, and white to white is normal..co loang as you 2 power legs are hooked to either power line, the bare goes to the nuetral/ground. thikn i mighta confused myself here, but theres no other way to wire it
Nov 07, 2008 | Cooktops
Polaris Pb4 - 60 Booster Pump Logo
110 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
