Question about Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
Manual admiral range abp34500 - Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
Cleaning self-cleaning oven on Admiral Electric range
Try the Maytag website under customer service. They usually will have the owners manuals You will need the model number.
Oct 03, 2014 | Maytag Admiral LER3330AAW / LER3330AAZ /...
How do I use the self cleaning feature on an old admiral stove? I cannot find the manual.
CLICK HERE for the manual
HOWEVER - I recommend NOT using this function - as this takes many components out of their normal heat range, and can cause damage/repairs.
The Self -Cleaning section starts on page 16.
Thanks!!
Aug 05, 2011 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Admiral stove manual
I have a Admiral gas stove model DF253660. The stove top operates as required but when turning knob for oven it does not light. What is the problem?
Jan 26, 2011 | Kitchen Ranges
Admiral range lgr333oadz. middle glass on door exploded
Unfortunately that is a very common thing...I see many of those problems go through Fixya everyday..
here are a couple of tips... one on replacing the glass and one on why not to use the clean mode...
heatman101
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Mar 26, 2010 | Maytag Admiral LGR3330ADW / LGR3330ADZ /...
My admiral designer series stove is showing a F 1
f-1 usuqally meens a stuck key pad.sometimes if you unplug it for a wile it may reset other than that you need to replace the clock/touchpad.
Mar 08, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Feb 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Locked door
try unplugging the stove and plug it back, that release the door on many of those models.
Dec 10, 2008 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Need a manual!!!
Maytag is now Whrilpool. Try looking here...
http://www.whirlpool.com/custserv/index.jsp
Jun 08, 2008 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range Logo
116 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
