Need ti put a stop on the automatic refill on my phone
When i put my 98 old's Cutlass in reverse it
change your transmission filter and fluid if its a automatic tranny ok dude ?if it is automatic transmission then that's your problem I know if your vehicle does not slip in any forward gears then go to the auto parts store and ask them for the tranny filter kit replacement and how many quarts of tranny fluid you need to put into it ok make sure you tighten the bolts in a sequence and no more then three fingers on a rachet and socket tight ok all evened torked and then add your fluid into the tranny dipstick tube using a tranny funnel ok
have a great day!
your helpful friend Robert W. Caston
Oct 04, 2014 | 1998 Oldsmobile Cutlass
MY VEH. IS AUTOMATIC SPORTTAGE 2001 MODEL AND HAVE LOCK ON ONE DRIVE GEAR ONLY L NEED HELP PLS.
If this issue is more likely to develop in cold climates, you will likely need to have your automatic transmission flushed, and refilled with fresh fluid. for now, put it in first and run the car with the brakes on. As if sitting at a stop lgiht. Give it a SLIGHT bit of gas, just enough that the engine is a bit above idle. This will generate some heat and hopefully warm the fluid enough that it will shift for you. Drive to your mechanic and have them check it out.
Do NOT use excessive throttle! You don't want to toast the transmission!
Hope this helps you out!
Jan 18, 2011 | 2001 Kia Sportage
When I refill the dispenser the Purell pours out and dose not stop. It isn't even foaming up.
when you put soap in do not cut tip or poke hole inbag just slide plastic tip in holder and close should work hope this helps
Sep 21, 2010 | GoJo Purell 2720-12: TFX ? Touch Free...
Refilled cartridges
the pixma range need to have the chips reset or refilled before they become empty.
Put in a genuine cartridge and it should work. Buy a set of cartridges with dummy chips that allow the printer to use refilled cartridges.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I can't turn off my headset option. although when i put it on vibrate only it refers back to ti and can't hear phone calls and others on line can't hear me. ku990i
when you have paired the device with another device,once the headset is powered on ,it automatically connects to mobile,cell,pc.........ect.
Nov 06, 2009 | LG KU990 Viewty
TI 83 Plus
Try hitting "ZOOM" then "0". This is for the "Zoom Fit" option. It will automatically adjust your window range to best fit your equation!
Sep 27, 2008 | Texas Instruments TI-83 Plus Calculator
My ti-83 plus has OS problem
That happened to me a few years ago - my friend tried to give me his operating system, and my calculator was all locked up like that for a while. There's some kind of reset code - pressing some buttons while putting a battery in - but it's been a while, so I don't remember which buttons.
Apr 15, 2007 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
