Question about Perlick H50IMS-ADL 15" ADA Compliant Clear Ice Maker With Stainless
I have a Perlick 15" residential clear Ice Maker that is not making very much ice. It is supposed to make 55 lbs of ice a day (and has been great for about 4 years) and now is probably making about 5 to 10 lbs of ice a day. In addition the cubes are small and not very think in size. There is no water leak. The water continues to flow through the machine and drip into the interior as it always has. It was thoroughly cleaned and sanitized 6 weeks ago and I ran the cleaning cycle twice in the last two days. I also took the "flaps" and a few of the "guts" out and turned it on and the water appears to spray up into the cube-making area as it should. Can anyone advise me what to do? Thank you!
Ice cubes are too thin. Making on time, but no volume due to small cubes. What part will correct this?
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
Jun 01, 2015 | Whirlpool Gold Series GI15NDXT 15"...
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
Our ice maker is not making ice. It's turned on but no ice is being made.
Check to see that the stop bar is down and that water is in the tray.
No water is often a bad inlet solenoid or water to fridge not on.
Sep 14, 2009 | Whirlpool Gold Series GI15NDXT 15"...
My icemaker makes large hunk of ice
IF YOU REMOVE THE FRONT COVER OF THE ICE MAKER THERE ID A SCREW TO ADJUST THE SIZE OF THE ICE CUBES TURN IT DOWN AND YOU WILL GET SMALLER ICE CUBES ALSO SOME MODELS HAVE A OUTSIDE KNOB TO ADJUST SIZE,LET ME KNOW-MIKE
Jun 17, 2008 | Whirlpool Gold Series GI15NDXT 15"...
Perlick H50IMS-ADL 15" ADA Compliant Clear Ice Maker With Stainless Logo
52 people viewed this question
Top Perlick Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Perlick Kitchen Appliances - Other Expert? Answer questions, earn points and help others
