Question about Exercise & Fitness
Proform j8li my treadmill lights up,incline/decline and turns on,but the motor doesnt make a sound and the treadmill wont move
    Top Expert:
  • 12,223 Answers
proform j8li - 810d2c26-b790-49c1-9641-93b05ea219e6.gifSee the video and lube .Of course you must do the same thign with rollers bearing front +back. Test the drive belt motor, and replace the belt if necessary.
However if after you lube the problem remain, is TIME to replace the deck belt by new ones.
You must test the control board, measure the input voltage for motor, if there are voltage the motor is faulty.
measure the output from control board if there are NOT voltage for input voltage motor, the control board is faulty , replace see the block diagram
God bless you
Posted on Aug 02, 2013
4 Suggested Answers
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
ercupa190
  • 12223 Answers
SOURCE: incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
Posted on May 08, 2012
ercupa190
  • 12223 Answers
SOURCE: My proform 685 LT treadmill will only incline and decline when turned on. It does this automatically. The belt will not run at all.
Run the software calibration for diagnose, troubleshooting, and fix it.
2) LUBE the deck belt, this happen by lack of maintenance, maybe you have the deck worn.
3) lube the rollers bearing too
4) measure the input voltage motor, if there are the motor need repair.
5) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
see the diagram
Posted on Jul 24, 2012
Pdoblem witn proform xp680 treadmill. Incline, decline works, when u start treadmill it runs for a second then shuts off and power goes out then comes back on and beeps twice
Hi sir
1) Please open the covert where the main motor is, disconnect
the connector from the Incline motor.
2) Turn On the treadmill, and see what happen.
3) If the problem does Not appear , is indication the controller motor board is defective.
Since the controller motor board has 3 power supply: 1) Console 2) Main Motor 3) Incline Motor.
LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
celular+WhatsApp:+50588611441
Mar 15, 2018 | Proform Exercise & Fitness
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Why won't my treadmill incline or decline?
Hi there, checked both upper and lower bolted connections, and check that lift motor hasn't cracked and frame is intact with no blockages to a possible scissor arm-lift assembly underneath the unit ? If this all checks out, maybe a small gearbox on the lift motor failed internally. Good luck.
Feb 02, 2015 | Proform Excellent Condition Pro-form 400e...
Pftl788071 incline
Sounds like the button on the panel is stuck somehow, I think this because when you switch the wires this would reverse the polarity to the incline motor.
can you tell if the panel is recognizing the pushing of the incline buttons, like with a beep or light or something? If it didn't seem like it's responding this may be because one button is constantly stuck down.
Apr 14, 2014 | Proform Exercise & Fitness
Incline stuck
Run the software calibration for fix it.go under the HOOD motor and follow the steps or use the owner manual
God bless you
Jul 26, 2013 | ProForm 775 CT Treadmill
God bless you
see the diagram
Jul 23, 2012 | Proform 695 LT Treadmill
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
May 08, 2012 | Exercise & Fitness
My T81 treadmill quit working. All of the lights and bells and whistles all work but the belt doesnt move and the incline doesnt move. Ive only had it for about 2 years. It was working fine before I moved...
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Mar 17, 2011 | Horizon T91 Treadmill
Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
I have a proform j8li treadmill, all 4 led lights work properly. Console lights all seem to work. Incline works fine but no belt motor function
Jan 26, 2010 | Exercise & Fitness
Exercise & Fitness Logo
177 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
