Question about Samsung PCJ522R 52" Rear Projection Television
Samsung PCJ-522R My TV is not showing blues / Greens very well. Kind of looks yellowish. Is there something I can do to get the picture back to its previous state. It has a manufacture date of 2001 S/N 39ZR300165Y Thanks, John
  • ama06483 Jan 17, 2008
    I am having a problem with my Samsung PCJ522R. The whites seem yellowish and blue looks green. The picture is also not very bright. I live in Seymour CT can anyone recommend a good service provider in CT?
    Tony
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Hey john if you look into the blue crt it will be very foggy..the coolant in the crt needs changing. you may want to contact a local tv repair person for more advice and coolant changing procedures....john
Posted on Sep 11, 2007
Our picture will only show reds and greens, no other colors.
Go to your On Screen Menu to picture settings and reset and choose "reset picture" mode. This will bring you back to factory defaults. If this doesn't work shut off wait 10 sec. and turn on the TV. If still no luck call your best friend who is a TV repairman, you probably have a damaged blue drive.
Oct 02, 2011 | LG 32LG30 32 in. LCD HDTV
How do you know if you need to replace the fluid? can you show me some pics of good red green blue color or some bad colors
If the glycol is bad, there is a easy way to tell:
Remove the back cover and with the set on use a small mirror--put it over each of the three Lens--red will never be bad this way.
What you want to see is a green picture on the green tube and a blue picture on the blue tube.
If instead of a picture either the green or blue look like a floodlight with no picture--the glycol is contaminated.
What happens is bacteria grows in the blue or green glycol--never the red--for some reason it does not like the red color.
Usually the blue will be the one first affected---picture will have a yellowish look over most or all of the screen (turn the color all the way down and stand back at least 10 feet and look at it,
Changing Glycol involves some important things---this stuff is like antifreeze bit ten times more toxic.
If you find yellow and want to know what is really involved respond to this posting and I will assist you.
If this information told you something you did not know, rate this solution as I do this here for free.
SD TECH
Aug 16, 2010 | Philips Magnavox 9P6034C 60" Rear...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Sony trinitron kv36fs13 the picture is fine but there is yellowish green tint on full screen
Yellowish tint in picture shows that TV needs increase in blue gain because picture tube is bit weak in result.
If you are handy with electronics repair then let me know to guide you further.
Jul 12, 2009 | Sony FD Trinitron KD-34XS955 34" TV
Yellowish picture everything else is good
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
Feb 28, 2009 | Samsung PCK520R TV
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
I have a ws-a65 tried to install 1080 hd quality through At&t u-verse missing green and red color only shows yellows and blues help!!!
im just going to assume you have it hooked up wrong, call a TV person and they can come look at it, its really hard to do this kind of thing over the internet
Oct 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Saturation of unrealistic color
It is definite CCD chip problem. If you are within warranty period, send it back quick. They probably replace with other unit because the parts are not available for the product. Good luck.
Mar 13, 2007 | Apex Digital 4330z Digital Camera
Color problem
my guess would be a cold solder joint on the av board. when picture looks good go to connectors and wiggle them if the set acts up you have your answer.
Jun 08, 2006 | Mitsubishi LT-3020 30 in. HD-Ready LCD...
Samsung PCJ522R 52" Rear Projection Television Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
