Question about Dell W3202MH 32 in. LCD Television
How to troubleshoot a Dell 3202mh lcd tv. I have no sound even thought I've tested the speakers and they work. Anyone have a diagram or know how to test components in audio circuit ?
  • 90 Answers
SOURCE: Sound proplem
its the audio amp, its fried and needs to be replaced. match the numbers up and purchase/replace boards, this will solve your problem.
Posted on Jan 31, 2009
  • 90 Answers
SOURCE: DELL TV 32" LCD TV
the problem is the audio amp board has been fried. It needs to be replaced. This will restore the actual sound transfer to and from the speakers.
Posted on Feb 08, 2009
  • 9 Answers
SOURCE: Dell W1700 no video no audio
It would probaly cost more than its worth to him to send out to get fixed. but thanks
Posted on Apr 19, 2009
Senco
  • 51 Answers
SOURCE: dell 37inch lcd tv no sound
You have bad sound module.
Guy at plasmatech@gmail.com should have it.
Very easy installatin
Posted on Aug 28, 2009
SD Tech
  • 14553 Answers
SOURCE: where can i get an Audio circuit boards for Dell Lcd Tv W 3201
I think you will find the answer is now no place will have them.
Posted on May 25, 2012
I have a Samsung LE40B650T2 - no sound direct from the TV
It sounds that the sound processing section [digital circuts] are working well, and the fault must be either to the speakers, settings or to analogue audio amplifier section. Make sure that the Mute function is OFF. If it is OFF, and still you do not get audio output by tV speakers, surely the fault must be to audio amplifier circuits, provided speakers are OK. If your TV has a headphone out socket, this socket should also checked for proper interconnection.
Jun 24, 2012 | Samsung LE40B650T2 40 in. Full HD Crystal...
Sound went out think its the speakers but not sure
If there is a buzzing sound coming from the speakers, when you listen closely the speakers probably went out, you should try connecting external speakers to the tv, if they work you know its the speakers if not, then it may be the TV screen itself, hope this helps.
Mar 14, 2011 | Dell W3201C 32 in. LCD Television
I have a Dell TV 32 In.LCD W3201\r\
I had the same problem with my dell tv. It's the exact same one you have. It kept making noise at first, and then the sound just went out. I changed the speaker wires to a slightly stronger, thicker wire and now it works great!! I hope this works for you.
Dec 05, 2009 | Dell W3201C 32 in. LCD Television
Dell 32 inch LCD Tv volume and menue problems
your main board is not communicating with the tv. it may be on the breaks of going bad, or simply needs a firmware update. questions, email me
May 24, 2009 | Dell W3706MC 37 in. LCD HDTV
Dell no sound
I also have Dell W2600 TV and have sound problems
Dec 14, 2008 | Dell W2600 26 in. LCD Television
DELL TV Speakers
hook another set of ext speakers to it. if no sound, its your audio bd not the speakers. hook ur dell speakers up to something else as well for verification.
Oct 22, 2008 | Dell W3000 30 in. HD-Ready LCD Television
DELL TV 32" LCD TV
Sep 06, 2008 | Dell W3201C 32 in. LCD Television
Weak sound from Dell W3000
Its possible that the speakers that came with the TV aren't amplified. Do you have another set of speakers that are to test the audio output?
Jul 26, 2008 | Dell W3000 30 in. HD-Ready LCD Television
We also have a 32" LCD Dell flat screen tv #W3201C that has no sound. It's about 2/12 yrs old. One speaker started having a problem and we disconnected it. That was a couple weeks ago, now there is no sound at all. Dell should not be let off the hook so easily. Obviously there is a problem with the tv and it should be Dell's responsibility to make it right. Does anyone know if a class action suit has been initiated?
Mar 08, 2008 | Dell W3201C 32 in. LCD Television
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
41 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
