Question about Fulton WB750 Wheel Bearing Kits
89 Ford Probe Right Rear Bearing - Fulton WB750 Wheel Bearing Kits
    Top Expert:
  • Fulton Master
  • 42,671 Answers
I just answered this but I forgot to mention that you have to replace both parts of the bearing--never mix old and new and never mix different brands in the same bearing.
Posted on Aug 07, 2013
89 ford probe hesitates when leaving a red light, then runs fine otherwise, fuel filter?
Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard ...
repairpal.com > Problems > Ford > Probe
Ford Probe Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard Starting, Poor Performance. This is a verified problem based on 9 reports. Learn more ...
Starting Problems - 1997 Ford Probe - RepairPal
repairpal.com > Questions > Ford > Probe > 1997 Ford Probe
Dec 5, 2010 - Starting Problems on 1997 Ford Probe ... If the engine runs rough,stalls, hesitates on acceleration, is hard to start, or has generally poor ...
A new misfire/hesitation on accel. Problem.. - ProbeTalk.com Forums
forums.probetalk.com > Tech Section > 2nd Gen (93-97) V6 2.5L
Feb 05, 2016 | Ford Cars & Trucks
Right rear wheel bearing for 89 Ford Probe GT, Replaced 4 times in 30 days.
If you are running tapered bearings then I would say that your problem is over-tightening and will destroy bearings very quickly. Too much or not enough grease will do the same . To properly grease new bearings you have to get the grease between the rollers and under the cage (that steel bit that holds the bearings apart) To do this place a small amount of grease in the palm of your hand and use the open end of the bearing to create a scraping action through the grease . This catches the grease and pushes it between the rollers. Do this action until you see it coming out the small end of the bearing. This is all the grease you need for a properly lubricated bearing. Repeat the process for the other bearing. Reassemble and fit the washer and locknut. Tighten the nut at the same time turning the wheel. When the nut is firm against the bearing but not tight turn the wheel a few more times. Now don't touch the wheel but loosen off the nut then retighten it up until it just touches the bearing. This is a no pre-load no end float situation that is most desirable for tapered roller bearings. Fit the split pin in the hole and open up the pin to catch it in the hole. If the pin hole will not allow this to happen tighten it just enough to get the first available slot to line up to allow the pin in. If you have thrust ball bearings they same method of greasing and adjustment is applicable.
Aug 01, 2013 | Fulton WB750 Wheel Bearing Kits
I need two new doors the door locks and handels are broken and someone stole the interior door panel
have you tried to go to a junk yard or to a ford probe forum? I had a 89 Ford Probe GT and had the same issues.
Dec 22, 2010 | 1993 Ford Probe
Where is the fuel pump in a 91 ford probe gt
Inside the fuel tank where the fuel line comes out.
Aug 08, 2009 | 1991 Ford Probe
Ford probe cuts in right hand turn
ford are notourious for starter solonoids going that would be the first thing id check its usually in the fenderwell near the battery-z
Feb 19, 2009 | 1986 Ford Ranger 2WD
89 Ford Ranger Carrier bearing
All the bearings for the rear diff are pressed off and on, they can be done at home if u have a high quality bearing puller, but to press them on should be done at the machine shop.
Feb 09, 2009 | 1989 Ford Ranger
Access panel for the fuel pump on a 1993 ford probe
the 93+ probe's (2nd generation) DO NOT have an access panel under the seats, or anywhere. only the 89-92 probe's did (1st generation) To gain access to the fuel pump, you have to drop the gas tank. or get handy with a cutter, and hope you dont blow yourself up.
Jan 07, 2009 | 1993 Ford Probe
Fulton WB750 Wheel Bearing Kits Logo
37 people viewed this question
Top Fulton Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Fulton Boating Expert? Answer questions, earn points and help others
