Question about Electric Mobility Health & Beauty
I have a Heartway Vita mobility scooter using a Rhino 110amp controller. It has two speeds Hihg/Low, I have a need to add a variable pot to control max speed in the Low/High Low setting just like they use in most other mobility scooters. I know it can be done but not sure of pot size and where to wire it in. Can any one help.
3 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: I have a pride scooter that will not run at top
hi, first check the speed throttle by moving it in the upwards direction while the speed control is turned fully on, if there is a response to moving the speed pot in up and down direction , you founf the fault, otherwise the speed control is at fault, if thats proves to be okay then its the controller breaking down , check the brushes on the motor.
regards
GeWiz
Posted on Dec 28, 2009
  • 177 Answers
SOURCE: I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning colintaylor1957@hotmail.co.uk"
I have an early version of a ew36 scooter and need to retrofit a speed pot. How do I do this, and any other info or schematics would be great. Thanks
The manufacturer has a variable speed control on the latest version of the ew36. My best suggestion is to contact the manufacturer for the part if it was not available on your version. They may have a retrofit kit with the harness and schematic so you do not have to reinvent the wheel or damage the existing components. You may need a new console cover where the speed control is mounted near the throttle lever. The manufacturer has done the work already and should provide the best guidance. Under driving the digital electronics with a home grown component may produce poor performance and potentially damage the controller sensing circuit. Hope this helps.
Jun 25, 2016 | Health & Beauty
Reprograming .RIHINO 110 controller formay DALTON eclectric four wheel monster scooter
hi Christopher, the Rhino 110amp is a excellent controller, what is the problem ?
Regards
Rob
Nov 12, 2015 | Health & Beauty
Manual for quingo plus
hi, I have repaired loads (100+) of Quingo and they are standard with most of the scooter parts except the gearbox,,,four bearings on the axle ,so well made ....
normally they fitted a Rhino 110amp controller so how i can help ?
a nice scooter except when the front assisted wheels bend , very dangerous as they take the pressure off the front wheel causing it to go straight so beware...when turning ...
Regards
Rob
www.gewizrepairs.co.uk
Apr 06, 2015 | Health & Beauty
Where csn I get throttle pot for a 2003 Sundancer scooter
I am thinking you mean a variable resistor that controls the speed of the machine. ( sometimes called a pot because of the shape) Record any details on the back of the pot and check on line under resistors variable , jaycar, electrical repair shops.
Oct 28, 2014 | Pride Health & Beauty
I have a IMC Heartway Gypsy and the power light blinks 5 times and the scooter won't run. I have just replaced the batteries. Is there list of what each code means? Thanks
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
May 18, 2014 | Pride Mobility Products Go Go Ultra X 3...
Pro rider speed controller
now that be a 110amp shoprider compatible unit, does your controller need repairing, I offer a free testing service...
Regards
Oct 26, 2013 | Health & Beauty
I have a silver leader 4 mobility scooter with a dynamic ds 100 unit under the rear end the status light is flashing 7 times which from what i have been able to find out is the wig wag potentiometre have...
hi,
ok so 7 flashes is a speed pot related error, you need to make sure that the speed pot is in the central position , look under the stem and you should see a cross head , now that should be straight not at slight angle, without you touching the throttle lever , if you have a meter disconnect the pot and take a resistance reading, it should show about 2.5K - using the centre tap , if it is a 5K pot fitted , in fact for that controller it should be a 5K pot , please check the terminal connections on the controller, good fitting and clean.
Take leave feedback.
Regards GeWiz.
Feb 11, 2011 | Power Health Scooter Wheelchair Programmer...
I have a 2002four wheel Legend Mobility scooter.
Hi. A lot of scooters have a seperate switch to select a high or low speed setting.
This switch is sometimes labeled indoor/ outdoor.
I have had a few scooters with a similar fault, and the wires that connect to the high/low switch have broken of the terminals on the rear of the switch.
It could also be a faulty speed control pot.
Check these and good luck. Neil.
Mar 08, 2010 | Pride Mobility Products Legend 4-Wheel...
Too slow how do I speed it up , a Pihsiang shop rider delux
hi, have you tried another charger as this sometimes can lead to batteries not 100% fully charged , I think the scooter in question is 6mph , check battery leads are a good connection and make sure the speed variable pot on the control panel is working correctly , is the speed pot working correctly (Wig wam) , try moving the lever in a upwards motion while moving forward , does it speed up ? if so it needs replacing.
Regards
GeWiz.
Oct 06, 2009 | Health & Beauty
Ajust speed
Yes, Unfortunately it is a technical solution, the twist grip speed control is a potentiometer (variable resistor) other then limited the amount the twist grip is turned , the only other way to limit the speed is to add a fixed resistor to the "top" end of the "pot", lets say you want a 10% reduction and you have a 1000 ohm pot you would add a 100 resistor to the "top" of the pot, if it doesnt work correctly change the connection to the other endof the pot
Mar 21, 2009 | Razor E100 Electric Scooter
Health & Beauty Logo
50 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
