Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
I have a cooltech model 347788 it stay on high presssure rest
Fuel presssure sensor high raildodge nitro 2.8 crd
check circuit and fuel pressure regulator for fault
Oct 25, 2016 | Cars & Trucks
My peerless furnace will not stay on
Could be the presssure switch try jumping it out and see if it stays on
Nov 16, 2012 | Heating & Cooling
I have a Samsung Cooltech Fridge/Freezer.....I changed the internal light bulbs and have no Internal light....what do I do ?????
before I sugest an idea I will ask you to make sure the new bulbs are not damage you can make a test with anything you may have at home that requieres a bulb less than 100 watts.if the new bulb is working unplug the fridge and try to pull out the center of the socket were the bulb rest is a small metal plate.use a pen,pensil plastic knif or regular kitchen knife tu open it but no to break it all the way just make sure your fridge/freezer is completly UNPLUG FROM THE POWER OUTLET
Aug 12, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung Cooltech spare shelves available in b'lore??
it is possibly cheaper to go to a glass firm and get glass cut and edges polished to fit than it would be to buy replacement shelves.the mark up is horrendous on any spare parts......
Apr 20, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Replaced pump and presssure vessel, water outside
If your like me your house has a pressure regulator to keep the pumps high cut out pressure from blowing your lines. Also a lot of domestic wells have a filter at the house to keep sediment out.
Sep 06, 2009 | Plumbing
Heater will not stay lit, 35000btu propane
try cleaning the the tube's to the presssure switch might be blocked
Jan 09, 2009 | Heating & Cooling
Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
May 15, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Assistance required
A thermostat would have nothing to do with this problem. Condensation occurs when warm air moves into a cold place. Check door gaskets or any possible way that warm air is getting into the cabinet.
Nov 07, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
71 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
