Question about Trademark Games Ideaworks Long Distance WiFi Antenna
Ideaworks antenna will not connect to wifi signal
Ideaworks wifi antenna driver download
With the computer on and in Windows, plug in the antenna. Then, go to Device Manager and find the antenna. Right click on it, and choose Update Driver. Let it look online, it may find a driver for it. Good luck.
Jan 11, 2018 | Computers & Internet
Why is the TV not connecting to wifi?
BECAUSE WIFI IS FOR COMPUTER SIGNAL FOR INTERNET ONLY TV IS FOR MONITOR VIDEO SIGNAL AUDIO SIGNAL FROM ANTENNA CABLE SATELLITE BOX THROUGH TUNER TV TUNER CAN NOT RECIEVE WIFI
Oct 18, 2015 | Televison & Video
Need software to download for an Ideaworks long distance WiFi Antennae. Need the drivers
You shouldn't need drivers. All you need to do is plug it in, go to your laptop, go to the bottom right of your machine and click on the wifi section
Full instructions should have been provided in the box.
I even found a video.
I cant link it but type this into google: ideaworks wifi antenna manual
Apr 05, 2015 | Computers & Internet
Not working
Some laptops may have a direct input for the Wifi antenna......you have to check with the manufacturer of the laptop if you dont see an input jack for an antenna. Usually those antennas are built into the laptop internally.
Mar 21, 2014 | Ideaworks Long Distance WiFi Antenna
Is there a WIFI Signal Booster out there for a Westell A90-750015-07 Router/Modem?
you don't need a signal booster. Instead what you need is a WIFI signal repeater. This device basically captures your router's signal and repeat it to other devices. Basically place is somewhere between the router and your computer.
There are many out there but here's a cheap one on ebay
http://www.ebay.com/itm/like/122201090687?lpid=82&chn=ps&ul_noapp=true
Apr 12, 2017 | Westell Wirespeed Computers & Internet
Can i add an outdoor antenna to my belkin f5d8236? how? do I connect to one of the existing antenna leads and forgoe the other? Do i need two outdoor antennas connected to it? I am trying to connect to...
I think you can try:
  1. Homemade Pringles antenna - Eat a packet of Pringles (ready salted would be my choice) then follow this tutorial to convert it into a functioning directional antenna. Point it where you need a signal boost.
  2. Airport Express & kitchen sieve - Take an Airport Express and set it into a common metallic kitchen sieve to boost it's signal further.
  3. Try a parabolic dish - Hawking make a 802.11 B/G parabolic dish that basically pulls in a WiFi signal, performs some magic and boosts your range by up to 300%! It only costs $80 and it has a cool retro style.
  4. Cantenna - This is basically a pro version of the Pringles tin hack. For $50 you can buy a Cantenna that plugs into your router and extends your WiFi signal. It also looks cool.
Also see this:
The Wi-Fire uses a powerful directional antenna, highly sensitive receiver and proprietary software to find and enhance normal WiFi signals. With it, you can connect wirelessly to the Internet-even at low signal strengths-faster, more reliably and with a more consistently strong connection-than you are able to with an internal wireless adapter.
The Wi-Fire draws very little power from your laptop battery. It comes complete with everything you need to connect wirelessly to the Internet. Just install the Wi-Fire Connection Manager, plug the Wi-Fire into an available USB port and you're ready to start. It can rest on any flat surface, laptop display or flat screen monitor.
Dec 31, 2010 | Belkin F5D8236-4 Router
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Trademark Games Ideaworks Long Distance WiFi Antenna Logo
114 people viewed this question
Top Trademark Games Electronics - Others Experts
Are you a Trademark Games Electronics - Other Expert? Answer questions, earn points and help others
