Question about Samsung Bluetooth?® WEP200 Headset (81451TMIN)
My wep 200 headset when fully charged works for about 10 minutes then it shuts itself off. why is this happening? The headset can be turned back on and will do the same thing over again, this tells me its not the battery, right?
5 Suggested Answers
  • 108 Answers
SOURCE: samsung wep 200 bluetooth #
try this website:
website
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Posted on Jan 22, 2010
SOURCE: Battery Backup of my WEP 200 Bluetooth Headset
I purchased new Samsung WEP 200 Bluetooth Headset but its Battery Backup is not even 1 minute. From where I can get the battery. I am based in Vijayawada, (A.P) (India) & what could be the approximate cost.
Posted on Feb 06, 2010
lock123
  • 6831 Answers
SOURCE: Samsung PL150 shut down after starting up, lens
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 05, 2010
lock123
  • 6831 Answers
SOURCE: I have a Samsung TL220.
Hello
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
My blueparrott not taking a charge can any one help me
It is actually very easy to remove the battery on the BlueParrott B250-XT. To remove the earpiece, just pull it out of the socket but be careful not to pull the wire attached to it when you separate it from the body. Next, remove the five screws to access the battery compartment. Disconnect the battery from the board and leave it disconnected for 10 minutes or so. Re-connect the battery and re-assemble. Connect the headset to your charger and after a couple of minutes, it should start charging showing red until fully charged. If it still won't charge, you may have to order a new battery. You can find a replacement battery on EBAY for around 10 dollars. Repeat the battery replacement and check to see if it starts to charge. If it works, you are good to go. If it does no work, you may have to send it to the manufacturer for repair. Good Luck!
Nov 11, 2014 | VXI Corporation Blueparrott B250-XT...
I have a BlueAnt Q2 that I just recently purchased. Even though I fully charge the device within about 10 minutes it will lose it's charge and shutdown. I've checked the batttery level and it...
levertjames,
Unfortunately you have a defective unit. I have seen several of these same units with the same issue. Return the item and get your money back. Thanks for visiting FixYa.com. Have a great day!
Sincerely,
TechGuy21
Jul 05, 2011 | Blueant Blue Ant 091022 X3 Micro Bluetooth...
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
My Garmin 1350 is fully charged. I used it
the software on garmin 1300 models is atleast 3.6/7 sounds like ur update didnt take, also check in settings see if you have a timer setting for sleep mode/stanby after x time
Dec 26, 2009 | Garmin nuvi 1350 Car GPS Receiver
Oct 29, 2009 | Samsung Bluetooth?® WEP200 Headset...
Bluetooth
I have a LG rumor phone from sprint and I am trying to program my bluetooth samsung WEP 200 and it is saying no bluetooth device found how do I set up the bluetooth I lost my instruction. The bluetooth was previously hooked up to the Razor phone
Sep 11, 2008 | Samsung WEP200 Headset
Cannot hear a thing after 3-4 minutes
what is the passkey for samsung wep200?
May 13, 2008 | Samsung WEP200 Headset
Wep 200
first switch off the headset and then press and hold the multifunctional button for 10 sec then the blue light gets constant then u search frm the phone
the code is 0000
Jan 22, 2008 | Samsung WEP200 Headset
Charging
There's a small power jack under a tab at the base of the unit. I found it only charges if you plug it into the transformer travel charger. For some reason plugging it in the PC USB port doesnt work.
If the unit is being charged a red LED will light up, turns blue after 2/3 hours when its fully powered up.
Jan 08, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung wep 200
Headset microphone may be off. Just press the volume up buttom and keep it pressed for 4 seconds or so, the pcs will beep twice to turn the mic on.
Aug 24, 2007 | Samsung WEP200 Headset
Samsung Bluetooth?® WEP200 Headset (81451TMIN) Logo
143 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
