Question about Haier CPRB07XC7 Portable Air Conditioner
I have a Commercial Cool and I dropped a flash drive into the front vent by accident and I need to get it out.
How do you drain a commercial cool unit
Remove the front lower vent cover and there should be a water tray/pan that should be accessible. If not, the whole refrigerator unit needs to be removed to gain rear lower access to the water pan.
Aug 25, 2016 | Refrigerators
Commercial cool dehumidifiers settings
In here commercial dehumidifier all settings & uses information Top 5 Selected Commercial Dehumidifier Reviews Buying Guide . Commercial dehumidifier generally best & stronger than other.
Jun 25, 2014 | Haier 11,000 BTU Commercial Cool Portable...
Air vent problems
You may have accidently disconnected something.
Jun 03, 2014 | 2003 Chevrolet Suburban
Steam iron turns itself from hot temperature to cool
1) test the electronic control for defective and follow the next steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
Cool air coming from the vents in the front but hot air coming from the back. What do I do to stop the hot air so that the room will cool down?
The hot air is a product of the cooling.... if you stop that then the unit will not cool!!!
You need to buy an exhaust kit to vent the hot air outside so that it will cool the room.
Otherwise it is just what is called a spot cooler or in other words you are cool if you sit in front of it, but it actually will make the overall room temp. hotter!!
heatman101
Jul 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
2006 Ford Expedition Limited - A/C blower does not blow in front
check connectors on control head,if look good,replace control head
Jul 05, 2009 | Heating & Cooling
Am trying to transfer DVD disc to Sandisk flash drive. What's the process? Thanks V
it sounds like you need to creat an .iso file from the dvd then drac and drop. is you flash drive 4 Gb
Jun 24, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
A/c doesn't blow unless high speed
Its your blower motor. Check the strip fuse (30 amp) outside the fuse box in a tootsie roll sized clip case by the strut mounts. In between the fuse box and strut mount. If not you may need a regulator or new blower motor.
Jun 05, 2009 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Haier CPRB07XC7 Portable Air Conditioner Logo
23 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
