Beko wm1520w washing machine all lights are on but cycle wont start?
  • Jan Pla
    Jan Pla Dec 16, 2013
    I have same problem with Beko 1520 N, all lights are on and cycle dont start. What can I do? Jan.
SOURCE: Beko WMA 1715S
try unplugging and let it reset itself
Posted on Apr 03, 2008
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Posted on Jan 03, 2010
SOURCE: My beko washing machine wont do anything at all!
Hi,have you ever solved the problem? Mine is doing exactly the same thing.
Posted on Aug 04, 2010
  • 6277 Answers
SOURCE: BEKO wma 250s washing machine does
This sounds very much like the belt is broken or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. It's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
  • 6277 Answers
SOURCE: my beko washing machine has
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
John C
Posted on Jul 12, 2011
My beko washing wont do a cycle instead jumps to spin then whilst trying to do a spin it jumps all over the kitchen
Hi if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first. there are a few possibilities here see below
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 21, 2014 | Washing Machines
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
Aa class beko washing machine wont spin or start a cycle
This Beko washing machine video will help you
We work very hard in our warehouse making free video guides for you all on cookers, ovens and washing machines Etc. Buy Paul Beer
Apr 02, 2014 | Beko Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
Beko washing machine stuck on rinse cycle water I drum but wont move onto spin
all you need to fix your beko
pump fault
or spin problem
i hope this helps
Buy Paul Beer
Jan 11, 2014 | Beko Washing Machines
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
May 17, 2012 | Beko Washing Machines
My beko wm5140w washing machine wont start cycle but lights are still on
Hi if your beko wm5140w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Dec 20, 2011 | Beko WM5140W
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
