Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Mach 4.7 runs for 2.5 minutes and shuts off
It runs for 2.5 minutes approximately and then shuts off. I cleaned the filters and it still does it. What should I do?
  • 70 Answers
Did you use it to vacuum up fine materials like powder? If you cleaned the filters, but they are original to the machine, replace them. Try changing the bag to a fresh one as well. Beyond that, check how freely the brush turns. If it doesn't turn freely that can but excess load on the motor, if its covered in threads, remove those.
Posted on Feb 04, 2014
4 Suggested Answers
  • 294 Answers
SOURCE: my hoover mach 6 bagless overheats, shuts off for
This is telling you that there is poor air flow or a blockage somewhere. To simply check for proper suction, remove the accessory hose to see if there is normal suction, if not then your problem is further in the unit. Troubleshooting from there will tell you where the problem is. Another possibility is that your thermal overload circuit is faulty. in this case a pro vac shop needs to service the issue.
Posted on Mar 01, 2009
wavoconqueso
  • 57 Answers
SOURCE: vacume is a mach 4 cyclonic, it runs for about 8
The only thing I can think of from your additional comments is when it warms up something expands and it loses continuity of the circuit. Most likely the switch or the breaker.
Another thing to check is if it has a hepa filter it may be clogged and is tripping the circuit. Try this. Remove the hepa filter, turn it on and let it run without vacuuming anything. If it continues to run past 10-12 minutes get a new filter.
Posted on May 10, 2009
  • 430 Answers
SOURCE: Hoover Mach 4 Overheats and shuts down after a few minutes
You have lost air flow due to blockage. Look for blockage in the throat of the machine where dirt enters from the floor. Do this by removing the base plate or opening throat inspection flap if so equipped. Also detach the hose and drop a coin through to see if there is and obstruction in that area.
Posted on Sep 08, 2009
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Sep 07, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Our Mach 5 turns off after running for about 5 minutes and smells hot!! Help!!! We have 3 kids and I need to Vacumn.
Hello:
Go here
Then find the clean filter section and clean all the filters especially the secondary filters. i think this will solve your problem.
Jul 07, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Vacume is a mach 4 cyclonic, it runs for about 8 minutes and then it shuts itself off? any idea?
May 09, 2009 | Hoover U8145-900 Savvy Bagless Upright...
My hoover mach 6 bagless overheats, shuts off for about an 1 hr will run again, all filters are clean, no blocks in hoses, how can i fix this problem
Feb 28, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Hoover Mach 5 sweeper
Hey all...
Had this same problem with my Mach 6 (same as Mach 5)
It would shut off after 15 min of use. What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Jan 28, 2008 | Vacuums
Mach 5 hoover turns off
Just got a solution off another website. There is a pre motor filter about the dust collection container. I opened mine and it was very dirty. I washed the filter and you are supposed to let it dry out for 24 hours. Hopefully this will work. Another guy said it worked for him.
Dec 29, 2007 | Vacuums
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
107 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
