Question about Acer Aspire T135 PC Desktop
I have a Acer Desktop, Model Aspire M1610. I turned it on and get maybe a 5-6 second beep, the beeping stops for maybe a 6-10 seconds and then starts beeping again for another 5-6 seconds, its a continues cycle. I have removed the memory 2 x 512 one at a time and reseated removed the key board and the mouse. I cannot figure this out. Anyone have any answers? Please help if possible!! Thanks in advance.
    New Friend:
    Problem Solver:
  • 17 Answers
Check your processor,Ram first
or board problem
Posted on Oct 17, 2013
PcExpert
  • 293 Answers
SOURCE: Acer Aspire T690 startup problem
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 19, 2007
Giddion
SOURCE: Acer Veriton 6800 PC Desktop will only beep will not boot.
reseat ram for a fast beeping and disconnect the power supply both the big and 4 pin connectors for 2-5 min plug in and boot. Plus you do not have to have pairs of mem only if you wand double data rate
Posted on Jan 10, 2008
leecom72
  • 4806 Answers
SOURCE: when i start my pc acer aspire m1641 after microsift corporation
go into the bios and make sure the USB controller are enabled, save settings and reboot if still same drivers are missing from the operating system, if you haven't got a password boot to windows and plug the keyboard in a different port to re-install the drivers. if you can't, does the computer support ordinary keyboards?
Posted on Nov 21, 2008
  • 233 Answers
SOURCE: ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
My acer 5741 boots but after 1 minute starts beeping once every 5 seconds.the beeping stops when i do something on the computer but starts again when the computer is idle.otherwise it works fine.any ideea?
Could be the cmos battery low voltage, the processor may be too hot, the video firmware may have errors ... could be all manner of things.
Try updating your drivers after checking the cmos battery.
May 12, 2014 | Acer Aspire 5742 Notebook
My tower beeps when i turn it on i have unplugged all the cords, transferred it to another power point and it continues to do this it beeps for 2 seconds and then beeps for 5 seconds and then pauses for a...
Try turning it off from the wall open the case and remove the ram (memory sticks ) from the mother board if there is one stick carefully clean the metal contacts with a new white eraser and reinstall it (if there are two sticks only replace one stick at a time ) if it boots with one stick then this was the problem if it doesnt boot and you have two memory sticks swap them and try again if it boots this time try shuting it back down and replace the second stic if it stops working again remove the faulty stick and replace it with a good one .(make sure you turn the computer of and unplug it every time you remove the memory .
I hope this helps Andrew a
Apr 07, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
My acer computer wont turn on it just beeps about every 5 seconds.
Those are beep codes-- for a hardware issue- I need to know the BIOS manufacturer and the exact code of the beeps--1-1-2 or 1long-2 short etc----also be sure all chips are seated correctly and nothing has changed since it last worked
Jan 18, 2011 | Acer Aspire One AOA150-1784 Netbook
The Acer X1700 desktop suddenly stopped booting.
i would check your power supply. take it to a local computer shop. or call acer for warranty support.
or if you are running on a backup ups, plug the computer directly into the wall and try it again
Sep 23, 2009 | Acer Aspire™ T180 PC Desktop
Acer aspire 7100 continually beeps while starting up
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
Nov 07, 2008 | Acer NSK8458AN Keyboard
Beeping
is the cpu in secure, try reseating it :)
Aug 21, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire T135 PC Desktop Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
